Fan Controll Issue
1.5k
    PeterA
    Hi all Help Appreciated. So I have everything except my Parts cooling fans working. I cannot get them to turn on when i use the fan slider in the web interface, nor on the panel due. The sliders work OK, in other words what i set the slider % to on the web interface is reflected on the panel due as the same.
    However even when i get the temps up on the hot end and even the bed, just in case, the fans do not rotate. I know they work as they where working with a slider on the old firmware, with assignment issues, but they worked. Any help appreciated.
    Below are the facts.
    • The fans are physically connected to the fan pin 1 not 0. For some reason pin 0 is faulty and hasn't worked, however pin 1 has.
    • The hot end fan is connected to always on and works fine.
    I have tried a number of config.g settings but no positive results. It almost like this pin is no not working as well. Not sure if there is something physical to look at like a fuse??
    here is part of my config.g settings and a pic.
    ; ##### Heaters #####
    M307 H0 A94.6 C545.4 D2.4 S1.00 V24.1 B0 ;PID tuning for Bed
    M307 H1 A309.5 C152.4 D4.9 S1 S1 V24.1 ;PID tuning for Nozzel
    M143 H1 S310 ; set temperature limit for heater 1 to 310C
    ; ##### Fans #####
    M950 F0 C"fan0" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
    M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
    M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
    M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
    ; ##### Tools #####
    M563 P0 S"Mosquito" D0 H1 F0 ; define tool 0
    The fans work together in the red circle, that's OK. The problem is the parts cooling fans on fan pin 1 don't spin up.
    Any help or advice appreciated.
      Veti
      @PeterA said in Fan Controll Issue:
      do you see the problem?
      undefined 1 Reply Last reply 31 Jan 2021, 10:09 Reply Quote 0
        Veti
        also Parts Fan is not a valid pin
        undefined 1 Reply Last reply 31 Jan 2021, 10:12 Reply Quote 0
          PeterA @Veti
          @Veti
          Not sure, is the F) meant to read F1?
          Im no programmer.
            Veti
            you said its connected to pin 1 but you configured pin0 "fan0" is the pin on the board
              PeterA @Veti
              @Veti said in Fan Controll Issue:
              Parts Fan
              Ok so should it read
              M950 F1 C'fan1" Q500
              and then
              M950 F1 C"fan1" Q500
              or do i just put that in once?
              undefined 1 Reply Last reply 31 Jan 2021, 10:13 Reply Quote 0
                Veti @PeterA
                if you connect the second fan to always on you can not control it.
                therefore the config to control the fan is not required
                delete
                  Veti
                  and dont change the f parameter
                    PeterA
                    Thank ok ill delete it. then do i change the other code to
                    Its not my field o expertise?
                      Veti
                      again dont change the f parameter
                        PeterA
                        sorry didnt see that
                          Veti
                          if you change the config. its a good idea to read the documentation what the parameters do.
                          e.g
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                            PeterA
                            Ok I'm trying this, hope I understood correctly, I've been through that document but I'm not getting it I guess. Its not through lack of trying 😉
                            ; ##### Fans #####
                            M950 F0 C"fan1" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
                            ;M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
                            ;M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                              PeterA
                              It's not working. Or did I misunderstand and I cant control them??
                                PeterA
                                The tool fan or hot end fan is always on and i don't want to control that, the parts cooling fan is connected to the pin in the diagram that i circled, and that's the one i want to control. I can not get them to come on at all anymore.
                                  Veti
                                  check that the fan is working by connecting it to the always on fan.
                                  however, if you for example swapped the polarity by mistake and connect the fan, you can blow the mosfet. then the port will either stay on or off, depending on how the mosfet failed.
                                    PeterA
                                    Thanks, I didn't change the connections and it was working, I'm not sure. The first pin Pin0 failed a while back so if you say the config is ok then I guess i have a failed mosfet. Not sure if that's changeable, I've changed a few on my Arduino board.
                                      Veti
                                      issue
                                      M106 P0 S1
                                      see if the fan turns on.
                                      if not. try fan2 port
                                        Veti
                                        and just to be sure. you restarted the duet after you made those changes?
                                          PeterA
                                          Thanks ill go try, the software rebooted the duet, ill try turn in off and on physically now
                                          9 out of 37
