    Fan Controll Issue
    1.6k
    • PeterAundefined
      PeterA @Veti
      @Veti
      Not sure, is the F) meant to read F1?
      Im no programmer.
      • Vetiundefined
        Veti
        you said its connected to pin 1 but you configured pin0 "fan0" is the pin on the board
        • PeterAundefined
          PeterA @Veti
          @Veti said in Fan Controll Issue:
          Parts Fan
          Ok so should it read
          M950 F1 C'fan1" Q500
          and then
          M950 F1 C"fan1" Q500
          or do i just put that in once?
          • Vetiundefined
            Veti @PeterA
            @PeterA said in Fan Controll Issue:
            if you connect the second fan to always on you can not control it.
            therefore the config to control the fan is not required
            delete
            M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
            M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
            • Vetiundefined
              Veti
              and dont change the f parameter
              • PeterAundefined
                PeterA
                Thank ok ill delete it. then do i change the other code to
                Its not my field o expertise?
                • Vetiundefined
                  Veti
                  again dont change the f parameter
                  • PeterAundefined
                    PeterA
                    sorry didnt see that
                    • Vetiundefined
                      Veti
                      if you change the config. its a good idea to read the documentation what the parameters do.
                      e.g
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                      • PeterAundefined
                        PeterA
                        Ok I'm trying this, hope I understood correctly, I've been through that document but I'm not getting it I guess. Its not through lack of trying 😉
                        ; ##### Fans #####
                        M950 F0 C"fan1" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
                        M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                        ;M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
                        ;M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                        • PeterAundefined
                          PeterA
                          It's not working. Or did I misunderstand and I cant control them??
                          • PeterAundefined
                            PeterA
                            The tool fan or hot end fan is always on and i don't want to control that, the parts cooling fan is connected to the pin in the diagram that i circled, and that's the one i want to control. I can not get them to come on at all anymore.
                            • Vetiundefined
                              Veti
                              check that the fan is working by connecting it to the always on fan.
                              however, if you for example swapped the polarity by mistake and connect the fan, you can blow the mosfet. then the port will either stay on or off, depending on how the mosfet failed.
                              • PeterAundefined
                                PeterA
                                Thanks, I didn't change the connections and it was working, I'm not sure. The first pin Pin0 failed a while back so if you say the config is ok then I guess i have a failed mosfet. Not sure if that's changeable, I've changed a few on my Arduino board.
                                • Vetiundefined
                                  Veti
                                  issue
                                  M106 P0 S1
                                  see if the fan turns on.
                                  if not. try fan2 port
                                  • Vetiundefined
                                    Veti
                                    and just to be sure. you restarted the duet after you made those changes?
                                    • PeterAundefined
                                      PeterA
                                      Thanks ill go try, the software rebooted the duet, ill try turn in off and on physically now
                                      • Vetiundefined
                                        Veti
                                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin
                                        also B4138 is incorrect. find the correct beta value in your thermistor documentation.
                                        PeterAundefined 1 Reply Last reply Reply Quote 0
                                        • PeterAundefined
                                          PeterA @Veti
                                          @Veti
                                          OK, i don't have any issues with the hot end or bed heating up and maintaining temp, not sure i understand the connection with the fans?
                                          • Vetiundefined
                                            Veti @PeterA
                                            @PeterA
                                            its not connected. but an incorrect value with result in an incorrect temperature being displayed.
                                            it could show 200 but the actual temperature could easily be 180
