    Fan Controll Issue
    1.6k
    • Vetiundefined
      Veti
      if you change the config. its a good idea to read the documentation what the parameters do.
      e.g
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
      • PeterAundefined
        PeterA
        Ok I'm trying this, hope I understood correctly, I've been through that document but I'm not getting it I guess. Its not through lack of trying 😉
        ; ##### Fans #####
        M950 F0 C"fan1" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
        M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
        ;M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
        ;M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
        • PeterAundefined
          PeterA
          It's not working. Or did I misunderstand and I cant control them??
          • PeterAundefined
            PeterA
            The tool fan or hot end fan is always on and i don't want to control that, the parts cooling fan is connected to the pin in the diagram that i circled, and that's the one i want to control. I can not get them to come on at all anymore.
            • Vetiundefined
              Veti
              @PeterA said in Fan Controll Issue:
              check that the fan is working by connecting it to the always on fan.
              however, if you for example swapped the polarity by mistake and connect the fan, you can blow the mosfet. then the port will either stay on or off, depending on how the mosfet failed.
              • PeterAundefined
                PeterA
                Thanks, I didn't change the connections and it was working, I'm not sure. The first pin Pin0 failed a while back so if you say the config is ok then I guess i have a failed mosfet. Not sure if that's changeable, I've changed a few on my Arduino board.
                • Vetiundefined
                  Veti
                  issue
                  M106 P0 S1
                  see if the fan turns on.
                  if not. try fan2 port
                  • Vetiundefined
                    Veti
                    and just to be sure. you restarted the duet after you made those changes?
                    • PeterAundefined
                      PeterA
                      Thanks ill go try, the software rebooted the duet, ill try turn in off and on physically now
                      • Vetiundefined
                        Veti
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin
                        also B4138 is incorrect. find the correct beta value in your thermistor documentation.
                        PeterAundefined 1 Reply Last reply Reply Quote 0
                        • PeterAundefined
                          PeterA @Veti
                          @Veti
                          OK, i don't have any issues with the hot end or bed heating up and maintaining temp, not sure i understand the connection with the fans?
                          • Vetiundefined
                            Veti @PeterA
                            @PeterA
                            its not connected. but an incorrect value with result in an incorrect temperature being displayed.
                            it could show 200 but the actual temperature could easily be 180
                            • PeterAundefined
                              PeterA
                              @Veti said in Fan Controll Issue:
                              M106 P0 S1
                              OK ill look into that, but just to confirm its not related to the fan issue?
                              • Vetiundefined
                                Veti @PeterA
                                @PeterA
                                that command is to enable the fan to 100%
                                • PeterAundefined
                                  PeterA
                                  B4138
                                  ok, after changing that the fans still don't come on at all. Ive put the jumper onto always on and the fans con on just fine.
                                  • Vetiundefined
                                    Veti @PeterA
                                    @PeterA
                                    no the beta has nothing to do with the fan
                                    what jumper?
                                    • PeterAundefined
                                      PeterA
                                      Ok.. so after plugging the jumper into always on then back to pin 1 they are now working????
                                      • PeterAundefined
                                        PeterA
                                        Must be like a faulty wiring connection.??
                                        • PeterAundefined
                                          PeterA
                                          Jip, everything now seems to work, I'll replace the connector, it looks OK but somethings off.
                                          • PeterAundefined
                                            PeterA
                                            B4138
                                            Thanks for your help.
                                            Regarding the B4138, i don't have any documentation regarding that. Ive looked through old setups and that's the one that its always used. How could i test this is correct?
