    Ender 3 Pro BL Touch Trigger Height
    Accessories and Add-ons
    2.6k
    • Vetiundefined
      Veti
      when defining the grid you have to take the offset of the probe into consideration.
      jcv1977undefined 1 Reply Last reply Reply Quote 0
      • jcv1977undefined
        jcv1977 @Veti
        @Veti But when i defined the grid i used the probe as point of reference thats why in reality all that coordinates are indeed reachable.
        • Vetiundefined
          Veti
          post the output of
          M208
          and
          G31
          • jcv1977undefined
            jcv1977
            M208
            1/31/2021, 11:22:02 AM	M208
            Axis limits X0.0:230.0, Y0.0:210.0, Z0.0:200.0
            G31
            1/31/2021, 11:23:07 AM	G31
            Z probe 0: current reading 0, threshold 500, trigger height 3.340, offsets X-46.0 Y6.0
              Post your config.g please.
              • jcv1977undefined
                jcv1977
                Config.g
                ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 12 2021 22:19:26 GMT-0500 (EST)
                G90                                           ; send absolute coordinates...
                M83                                           ; ...but relative extruder moves
                M550 P"Ender 3 Pro"                           ; set printer name
                M552 S1                                       ; enable network
                M586 P0 S1                                    ; enable HTTP
                M586 P1 S0                                    ; disable FTP
                M586 P2 S1                                   ; disable Telnet
                M569 P0 S0                                    ; physical drive 0 goes backwards
                M569 P1 S0                                    ; physical drive 1 goes backwards
                M569 P2 S1                                    ; physical drive 2 goes forwards
                M569 P3 S0                                    ; physical drive 3 goes forwards
                M584 X0 Y1 Z2 E3                              ; set drive mapping
                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping without interpolation
                ;M350 E16 I1                                   ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z397.44 E449.62              ; set steps per mm
                M566 X900.00 Y900.00 Z24.00 E180.00           ; set maximum instantaneous speed changes (mm/min)
                M203 X7000.00 Y7000.00 Z5000.00 E500.00      ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z150.00 E350.00         ; set accelerations (mm/s^2)
                M906 X900 Y900 Z900 E900 I60                  ; set motor currents (mA) and motor idle factor in per cent
                M84 S40                                       ; Set idle timeout
                M208 X0 Y0 Z0 S1                              ; set axis minima
                M208 X230 Y210 Z200 S0                        ; set axis maxima
                M574 X1 S1 P"xstop"                           ; configure active-high endstop for low end on X via pin xstop
                M574 Y1 S1 P"ystop"                           ; configure active-high endstop for low end on Y via pin ystop
                M950 H3 C"nil"                                 ; Disable heaters h3-h7 to free up pins
                M574 Z1 S2                                    ; configure Z-probe endstop for low end on Z
                M950 S0 C"exp.heater3"; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H6 F200 T2000           ; set Z probe type to bltouch and the dive height + speeds
                M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
                ;Bed Height adjustments
                G31 P500 X-46 Y6 Z3.34   ; set Z probe trigger value, offset and trigger height
                M557 X47:205 Y20:230 S20                      ; define mesh grid
                ;M557 X47:205 Y20:230 S32                      ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                         ; create bed heater output on bedheat and map it to sensor 0
                ;M307 H0 B0 S1.00                              ; disable bang-bang mode for the bed heater and set PWM limit
                M307 H0 R0.304 C437.7 D7.20 S1.00 V24.0
                M140 H0                                       ; map heated bed to heater 0
                M143 H0 S80                                   ; set temperature limit for heater 0 to 80C
                M308 S1 P"e0temp" Y"thermistor" T98801 B4185  ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                          ; create nozzle heater output on e0heat and map it to sensor 1
                ;M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
                ;M307 H1 R2.305 C156.6 D6.40 S1.00 V24.0
                M307 H1 R2.303 C154.7 D6.52 S1.00 V24.0
                M143 H1 S250                                  ; set temperature limit for heater 1 to 250C
                M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H T45                              ; set fan 0 value. Thermostatic control is turned on
                M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1 T45                             ; set fan 1 value. Thermostatic control is turned on
                M563 P0 S"Hotend" D0 H1 F0                    ; define tool 0
                G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
                G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
                T0                                            ; select first tool
                G28
                ;M558 P9 H5 F100 T2000
                ;M558 P9 C"^zprobe.in" H5 F100 T2000  ; BLTouch connected to Z probe IN pin
                ;M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
                ;G31 X-46 Y6 Z3.02
                ;M501
                • Vetiundefined
                  Veti
                  @jcv1977 said in Ender 3 Pro BL Touch Trigger Height:
                  this does not match your config.
                  check all your files maybe you are overwriting it somewhere
                    Your Z probe is in front of the nozzle by 6mm, so it's unable to reach the Y position you've set in M557.
                    • jcv1977undefined
                      jcv1977 @Veti
                      @Veti 👍
                      • jcv1977undefined
                        jcv1977 @Phaedrux
                        @Phaedrux no, it's behind the nozzle, maybe i wrongly put positive 6 when it is negative? That's why i am sure that every single coordinate can be reach i've saw myself the whole measurement and the probe can reach all of them fine.
                          Ah yes, sorry. Y6 would be behind the nozzle.
                          Veti pointed out the real issue.
                          Your M557 is asking it to go to 230 but your axis maximum is only 210. The error messages say it's skipped 220.
                          • jcv1977undefined
                            jcv1977
                            I am glad to report that now it's working. But just because i am a control freak i 've modified my bed so its better now and i am assuming that once i've done the compensation and save the height map the only thing that i need to do is just load that map at the beginning of the print.
                            Thanks guys
                              Phaedrux Moderator @jcv1977
                              Yes, G29 S1 in the slicer start gcode after the G28 to home would be a good place.
                              • b3njam1nundefined
                                b3njam1n @jcv1977
                                @jcv1977 Hey, is that the editor in DWC? How did you get it to parse Sometimes as a valid gcode?
                                • jcv1977undefined
                                  jcv1977 @b3njam1n
                                  @b3njam1n Hey! just use the code snipet and paste your gcode inside it.
