    duet 2 wifi reported error auto reconnect failed
    Duet Web Control
    774
    • uneumann36undefined
      uneumann36
      @Phaedrux said in duet 2 wifi reported error auto reconnect failed:
      M98 P"config.g"
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
        uneumann36
        ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sun Nov 29 2020 14:26:01 GMT+0100 (Mitteleuropäische Normalzeit)
        M550 P"SILENT GOLIATH" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z400.00 E141,12 ; set steps per mm
        M203 X6000.00 Y6000.00 Z180.00 E2000 ; set maximum speeds (mm/min)
        M201 X800 Y800 Z250 E1250 ; Set accelerations (mm/s^2)
        M906 X1500 Y1500 Z1500 E1000 I35 ; set motor currents (mA) and motor idle factor in per cent
        M84 S35 ; Set idle timeout
        M208 X400 Y400 Z400 S0 ; set axis maxima
        M574 X1 Y1 S1 ; X home to min. Y home to max. Normally Closed limit switches.
        M574 Z1 S2 ; Define Z to use Probe. Home to Min
        M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
        G31 P25 X45.1 Y-2.5 Z3.220 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
        M557 X5:205 Y5:165 S20 ; Define mesh grid
        ; BLTouch - Heaters
        M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
          When it appears to be frozen can you connect via USB terminal and see if it's still operating?
            uneumann36
            Hi Guys,
            So i will report you, i don´t know why.
            I have not changed settings or so on.
            But till now the connection is stable and no connection lost anymore.
            Will keep you informed.
              uneumann36
              Dear Friends
              I am sorry to ask you again for help.
              I was not able to print a few weeks.
              But this issue is not happen again.
              Now i have 2 printers , both with Duet 2 wifi.
              I noticed, this happens when the wifi is down from the router for a few seconds, and come back.
              Then both duet´s don´t conect again.
              And Panel is frozen , touch is working, but this will not adjust something on the board.
              I mean in this moment, when i give the command for example M552 nothing happens.
              Please help me.
              Thank guys.
                uneumann36
                It happens between the printer is printing, but the print will go to the end ,
                result is good, but wifi connection is not working anymore till i switch off and on the printer.
                Also i try to connect printer between printing via USB and Prontaface.
                Not possible to conenct the Printer.
                (In Device Manager Printer is there when i connect USB )
                So please help me
                  What does it say on the PanelDue in the top right corner when it's not responding?
                  After this is happened are you able to power cycle the duet and connect again?
                  After you re-connect can you send M122 and post the result?
                  uneumann36undefined 1 Reply Last reply Reply Quote 0
                    uneumann36 @Phaedrux
                    @Phaedrux
                    Thank you for your reply.
                    In the right corner is written printing.
                    When i switch off and on the printer, everything is all right and working.
                    Also if i disconnect the panel and connect it between this happen, same result.
                    On both printer.
                      Considering you're still running firmware 2.05 I might suggest updating to take advantage of bug fixes and improvements since then. However updating to RRF3 would require some changes to your config files. If your printer is fairly standard you should be able to create a new config set using the online tool and make any needed changes to that.
                      If you wish to test it out.
                      If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                      That will get your firmware and DWC up to date.
                      For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                      https://configtool.reprapfirmware.org/Start
                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                      You'll also need to update the PanelDue firmware.
                      https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                        @Phaedrux
                        Sounds good !
                        I already try it in the morning, but without your steps.
                        And i got the problem that the temperatures of heaters was not present, or -273
                        Do you mean a new online configuration solve this temperature issue?
                        After i set with online tool my config,
                        Can i use my old config special settings?
                          Phaedrux Moderator @uneumann36
                          @uneumann36 said in duet 2 wifi reported error auto reconnect failed:
                          Mostly. Some commands might need to be modified.
                            @Phaedrux
                            Yeah, i will do this after my finished print.
                            Hope it will work with my limited knowledge ! Smile.
                            I case not, i hope i can contact you again.
                              It will help to do some reading in advance. Also generate a new config using the tool before you start then compare what it generates to what you have now to see the differences.
                              Example of RRF2 and RRF3 files: https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY
                                @Phaedrux
                                So , i want to tell some things about this forum and you!
                                I am so happy to get this kind of great support, this is absolute wonderful.
                                I am a technician in technical support worldwide, but you, this is great.
                                And all this support is free of charge!
                                Thank you verry verry much!!!!
                                But i know thank you is not all!
                                Please let me know how i can aid you and this forum.
                                Special Thank`s from germany.
                                  Pay it forward. Once you have a good understanding of what you're doing, spend some time helping other beginners get started. 😉
                                  uneumann36undefined 2 Replies Last reply Reply Quote 0
                                    @Phaedrux
                                    So, i will report that the update to V3.2 is done.
                                    Also i make a new Cofig via tool, bring on my printer, and it is working.
                                    So i change some settings in the config to get my printer in near old conditions.
                                    So printer work fine via DWC
                                    I try to update Panel also Via Bossa and USB.
                                    I try a lot a Software Versions but no one is working!
                                    In best conditions i got the screen shows everything, but no connection to Duet2Wifi!
                                    What can i do??
                                      uneumann36
                                      Is there anyone who has an idea?
                                        • Vetiundefined
                                          Veti
                                          did you enable paneldue support ?
                                            uneumann36
                                            Sorry for the Question, what does ist mean ?
