    duet 2 wifi reported error auto reconnect failed
    Duet Web Control
    774
    • uneumann36undefined
      uneumann36 @Phaedrux
      @Phaedrux
      Sounds good !
      I already try it in the morning, but without your steps.
      And i got the problem that the temperatures of heaters was not present, or -273
      Do you mean a new online configuration solve this temperature issue?
      After i set with online tool my config,
      Can i use my old config special settings?
        Phaedrux Moderator @uneumann36
        @uneumann36 said in duet 2 wifi reported error auto reconnect failed:
        Mostly. Some commands might need to be modified.
        uneumann36undefined 1 Reply Last reply Reply Quote 0
          @Phaedrux
          Yeah, i will do this after my finished print.
          Hope it will work with my limited knowledge ! Smile.
          I case not, i hope i can contact you again.
            It will help to do some reading in advance. Also generate a new config using the tool before you start then compare what it generates to what you have now to see the differences.
            Example of RRF2 and RRF3 files: https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY
              @Phaedrux
              So , i want to tell some things about this forum and you!
              I am so happy to get this kind of great support, this is absolute wonderful.
              I am a technician in technical support worldwide, but you, this is great.
              And all this support is free of charge!
              Thank you verry verry much!!!!
              But i know thank you is not all!
              Please let me know how i can aid you and this forum.
              Special Thank`s from germany.
                Pay it forward. Once you have a good understanding of what you're doing, spend some time helping other beginners get started. 😉
                uneumann36undefined 2 Replies Last reply Reply Quote 0
                  @Phaedrux
                  So, i will report that the update to V3.2 is done.
                  Also i make a new Cofig via tool, bring on my printer, and it is working.
                  So i change some settings in the config to get my printer in near old conditions.
                  So printer work fine via DWC
                  I try to update Panel also Via Bossa and USB.
                  I try a lot a Software Versions but no one is working!
                  In best conditions i got the screen shows everything, but no connection to Duet2Wifi!
                  What can i do??
                    uneumann36
                    Is there anyone who has an idea?
                      @Phaedrux said in duet 2 wifi reported error auto reconnect failed:
                      • Vetiundefined
                        Veti
                        did you enable paneldue support ?
                          uneumann36
                          Sorry for the Question, what does ist mean ?
                            The PanelDue will need to be at least version 1.24 or higher, and you will need M575 P1 B57600 S1 in the config.g to enable the paneldue in RRF3. This may already be there if you selected Enable PanelDue support in the config tool.
                              uneumann36
                              M575 P1 B57600 S1
                              Oh Man!
                              Yes ecatly this was the reason.
                              It works now, thank you very much.
