    Unable to attach after network wireless IP change
    Using Duet Controllers
    1.8k
    • crchisholmundefined
      crchisholm @Phaedrux
      @Phaedrux said in Unable to attach after network wireless IP change:
      Ok.
      Now send these commands and let us know what it responds with.
      M552 S0
      M552 S1
      M588 S"*"
      Now to connect it to your wifi network you need to send the M587 command.
      See here for the steps: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
      M552 S0
      ok
      WiFi reported error: no known networks found
      WiFi module is idle
      M552 S1
      ok
      WiFi module is idle
      WiFi module is idle
      M558 S"^"
      ok
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      Sadly, I am beginning to believe the board is dead.
        Phaedrux Moderator @crchisholm
        @crchisholm said in Unable to attach after network wireless IP change:
        M558 S"^"
        Did you really have ^ ? It should be *
        There's nothing to indicate this. I think the problem is you just need to add your SSID name and password.
        crchisholmundefined 1 Reply Last reply Reply Quote 0
          @Phaedrux Darn. To much going on. Yes. I did enter the ^ instead of the *. I guess my printer isn’t the only one with issues. I am away from my home computer so I will rerun these tomorrow.
            You can create a macro like this and place it in the /macros folder. Add your network name and password. Save it as addwifi
            M552 S0			; Disable network module
            G4 S5			; wait 5 seconds
            M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
            M552 S1			; reenable wifi module
            Then from the USB terminal send M98 P"addwifi"
              @Phaedrux First off, I am not sure how to save this as a macro when I can't even get into the device.
              I reran the three commands being more careful to avoid typos.....
              WiFi module is idle
              M552 S0
              ok
              WiFi module is idle
              M552 S1
              ok
              WiFi module is idle
              WiFi module is idle
              ... repeats forever ....
              M558 S"*"
              ok
              WiFi module is idle
              WiFi module is idle
                You would need to put the SD card in your computer and use a text editor like notepad to create the macro file.
                Or just download this file
                addwifi.g
                Open it in a text editor and add your SSID and password and put it on the SD card.
                Then from the USB terminal send M98 P"addwifi.g"
                  crchisholm
                  Ok, I have done that. I copied the file to the MACROS folder on the SD and confirmed that it was readable and contained the correct info. I used your name "addWifi.g".
                  So now I am unsure where to go. How can I run that macro if I can't connect to the Duet????
                    Did you also change the macro to use your own SSID and password?
                      M98 P
                      result...
                      M98 P
                      Warning: Macro file not found.
                      ok
                        crchisholm @crchisholm
                        @crchisholm Crap....just saw what I did wrong
                        M98 P "addWifi.g"
                        Warning: Macro file "addWifi.g" not found.
                        ok
                        but alas, it did not make a difference....
                          Are you sure that's what it was named and it's saved in the macros folder?
                          Did it keep the .g extension?
                            Also there should be no space between the P and the macro name
                              @Phaedrux
                              There are no spaces
                              I did a copy/past of your suggestion above and copied it into a file named addWifi.g. My system seems to want to capitalize the “W” so I went with that through out.
                              I copied that file to the sd macros folder.
                              I opened the file on the Sd and double check that everything is correct.
                              I reinserted the sd into the duet.
                              I powered the duet up and sent M98 “addWifi.g”
                              ...could not find the file.
                              I also reformatted an Sd card, copied the addWifi.g to the macros folder, opened it in notepad++ and checked everything again. I tried that SD card and got the same result.
                              When do I decide the problem is on the board itself. I have seen absolutly no indication that the WiFi module even works. If the board has gone bad, then I’m out ofluck. Like so many others, the pandemic has left me in the position of not being able to replace it. (Not whining ...I’m well aware there are lots of folks in the same mess)
                                jay_s_uk
                                he means you had typed a space between P and "addWifi.g"
                                you should be sending
                                M98 P"/macros/addWifi.g"
                                  crchisholm @jay_s_uk
                                  @jay_s_uk ahhhh! Didn’t see that. Will try again.
                                    What exactly is in addwifi.g?
                                    Try M98 P"0:/macros/addwifi.g" just to specify the entire path.
                                    Again, I don't think there is anything wrong with the board. So far it is behaving as expected to the commands it's been given. It just needs the wifi network added. Once we can get the macro to execute to send the M587 command we should be in business.
                                      crchisholm
                                      Wow! Woke up this morning and fired up the printer expeecting to continue the saga. Looked over and what did I see..... A shinny blue light peaking back at me.
                                      Don't know how, but some of the changes I made last hight (per you'all's suggestions) seemed to have kicked in. Not sure whey it did it wouldn't work last night but did this morning, but i think I'll leave that horses mouth shut.
                                      Thank you all. I'm quite sure that this is because of your help.
                                        Glad to hear.
