    Trouble of connection to Duet 2 wifi
    Using Duet Controllers
    410
    • pavelsplavelundefined
      pavelsplavel
      Hello! I trying follow steps of getting started and firmware installation. Have trouble to connect to device. For Bossa and SAM-BA the result is same. Cant connect.JPG
        pavelsplavel
        5 and 3.3v is turned On.
        • Vetiundefined
          Veti
          if the device is reported as duet then its not in bossa flash mode.
          see
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
            A Former User
            If the board does identify as a Duet serial port, I think the preferred solution is to use M997 over a serial terminal to update the firmware (after placing the binaries on the sd-card)
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
            Or even the web interface if you're able to set it up using
            https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
            and
            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
              pavelsplavel
              I forgot to said: I ve done erase 2 times before.
                A Former User @pavelsplavel
                @pavelsplavel said in Trouble of connection to Duet 2 wifi:
                for this board? it shouldn't identify as a Duet to the device manager if it has been erased
                • felekundefined
                  felek
                  @pavelsplavel
                  Turn on board -> put jumper on erase pins -> press restart button -> pull off jumper -> press restart button one more time.
                  After that procedure I hope the microcontroller will erased. If not check your jumper and reset button
                    pavelsplavel
                    @felek You made my day.
                    Thanx to all !!
