    Scara support ?
    16.4k
    • frafaundefined
      frafa
      Without the homing currently you can add M206 to calculate the position x0 / y0 with respect to the axis of the first arm, No?
      And after when the homing will be functional you will add the offsets …
      Scara with DuetWifi => Scarlette3D
      https://youtu.be/mBF5cO8vGhI
        I've decided to add X and Y parameters to 1.19beta9 to allow the bed to be offset from the proximal joint. I will also change the way that the crosstalk factor works, which will have the effect of making C0:0:0 correct for your machine and C-1:0:0 correct for the Helios.
        Until homing is implemented, I suggest you manually move the arms (slowly, to be kind to the electronics) so they are in line and the proximal joint is at the half way position. Then power on. The displayed coordinates should show Y=0 and X= just below the sum of the arm lengths. If you then send a G92 command with the same X and Y coordinates as the displayed ones, it will then consider that the machine has been homed.
        We're planning to display a Helios at the TCT show in September, which means that I will get SCARA homing working before then.
          Firmware 1.19beta9 is out, with added X and Y bed origin offsets and a fix for G92 X0 Y0.
          • frafaundefined
            frafa
            Oup's…
            I had not seen page 2 of the post 😞
            A big thank you for your responsiveness !
            I test this afternoon at fablab
            • frafaundefined
              frafa
              Again a big thank you for your responsiveness
              My tests:
              The M669 command used (X150.0 Y-61.0):
              M669 K4 P200 D200 A-175:175 B-175:175 1:0:0 S200 X150.0 Y-61.0; set SCARA kinematics parameters
              ok
              Test moves First arm of 20 ° it's ok?
              G1 S2 X10 ;anticlockwise
              G1 S2 X-10 ;clockwise
              ok
              Test moves second arm of 20 ° it's ok?
              G1 S2 Y10 ;anticlockwise
              G1 S2 Y-10 ;clockwise
              All movements in Pronterface in debug mode return:
              SENDING:G92 X0 Y0
              [ERROR] Traceback (most recent call last):
              File "printrun\printcore.pyc", line 241, in _readline
              File "printrun\pronterface.pyc", line 1713, in recvcb
              File "printrun\pronterface.pyc", line 1669, in update_pos
              ValueError: could not convert string to float:
              Homing goes in the right direction x/y/z
              I manually move the arms to position x0/y0
              I power on with Pronterface I send command G92 X0 Y0
              I'm testing x/y placements everything works but upside down
              When i do x + i get an x-
              And when i do a y + i get a y-
              I reverse the engines in config.g and the displacements do anything?
              I put the file config.g normal, and I reverse the connector of the engines,
              Same results the movements do anything
              In short I did not succeed in reversing the meaning, how to do?
              It's almost perfect we're not far 🙂
                In writing the firmware I assumed that the bed is to the right of the proximal joint, and the zero angle position of both arms is with them stretched out to the right so that they point towards the +X direction. Do you by any chance have your arm mounted the other way round?
                • frafaundefined
                  frafa
                  hi
                  My Kinematics
                  for later 😛 End-stops (hall effect +on5v) are on X22.00 Y-35.00
                    Ok, so what i have assumed is +X is your +Y, and what I have assumed is +Y is your -X. Thinking about it, there are 4 possible orientations of the bed if we only consider the obvious ones, and I guess the firmware should allow any of them in a configuration option. Or maybe it should allow an arbitrary bed rotation angle.
                    For now, if you define the top left corner of the bed in your diagram as (0,0) and the axis directions as I have assumed them, then you should be able to print
                    Regarding homing, I was assuming there will be a limit switch at one end of the travel of each joint.
                    • frafaundefined
                      frafa
                      Of course I'm stupid, I did not think about it
                      • frafaundefined
                        frafa
                        Hi
                        define the top left corner of the bed, change on M669 x/y
                        and print…
                        ok 🙂
                        Video, sorry the machine is under development all is not clean ...
                        http://www.openhardware.eu/tmp/DuetWifi/VID.mp4
                        I still have to solve the same vibrations as with Smoothie …
                        My M669
                        M669 K4 P200 D200 A-175:175 B-175:175 1:0:0 S200 X118.0 Y-150;
                        My reduction motor and pulley
                        Motor 400 step/revolution 0.9°
                        Pulley 80/16
                        Microstepping 256
                        Calcul Step/° X/Y (Réduct 80/16) ==> 400256(80/16)/360=1422,2222222222222222222222222222
                        What can be the cause in your opinion not enough mechanical reduction, or other ?
                        Thank you very much !
                          I'm glad you are making progress.
                          Have you tried adjusting the segments/sec and minimum segment length in the M669 command, to see whether it affects the vibration?
                          • frafaundefined
                            frafa
                            I am also pleased ! 🙂
                            Not tried, i test tomorrow.
                            • frafaundefined
                              frafa
                              I've done a lot of testing, and the best configuration seems to be
                              M669 S200 T0.5
                              It's not perfect, but it's better
                              But on another piece the result is not satisfactory
                              Saturday I tried on cubes and diamonds to try to understand,
                              Because the vibrations seem to be present only on the diagonals of the bed …
                              If you have an idea to improve ...
                              I will redo the arm to pass in reduct of 160/16
                              And GT2 belts 10mm high to see if it improves
                              http://www.openhardware.eu/tmp/DuetWifi/VID_20170713_181706.mp4
                              • frafaundefined
                                frafa
                                I'm Happy 🙂
                                It is almost perfect there are still some vibrations but I think I can further refine the firmware settings
                                I completely redraw the arms of scara
                                Now reduction 160/16
                                pulley DIY gt2 lasercut and Wide belt 10mm high
                                New experimental firmware 1.19beta10
                                http://www.openhardware.eu/tmp/DuetWifi/new/VID_20170721_171557.mp4
                                • number40fanundefined
                                  number40fan
                                  I can't help to think how a set of shock absorbers would help. You have so much mass hung out so far that you are trying to stop and start. Am I wrong in thinking that something that could help dampen the movement would help?
                                    I'm glad you are making progress! You are the first person to use RRF or a Duet on a Scara printer.
                                    I'll try to implement Scara homing before the 1.19 release. You will need a microswitch at one end of the movement range of each joint.
                                    • frafaundefined
                                      frafa
                                      Thanks to you for your reactivity !
                                      The endstop will be hall effect 3v logic / v+ on 5v (banggood model)
                                        Is your SCARA printer home designed and built, or is the mechanics built from a kit? We're looking for some SCARA mechanics to use as a test bed for the SCARA support in RRF.
                                        • frafaundefined
                                          frafa
                                          Hello
                                          This is a model designed by me being created,
                                          It will be open-source when finished
                                          Download Sketchup 2016 model of the current model being developed: http://www.openhardware.eu/tmp/DuetWifi/scara-v5.skp
                                          humm … google translate ...
                                          Evolutions in progress not final model, but functional...
                                          • frafaundefined
                                            frafa
                                            A big thank you for the support of Scara and end stops on version 1.19RC1
                                            I test tomorrow 🙂
                                            My end stops are not exactly on X0/Y0 M206 is supported ?
                                            and move in X0/Y0 after homing ?
