    Recommended pulley's for Delta printer
    • Falkiaundefined
      Falkia
      Any recommendations for the pulley size for a delta printer (16 or 20 teeth)?
      Bed size: D500mm
      Motors are Nema17, 42BYGHM810.
      Step Size: 0.9°
      Rated Current: 2.4A
      Rated Holding torque: 4200gcm
      Resistance: 0.8Ω
      Inductance: 1.8mH
      Detent torque: 220gcm
      Thanks
      Fredrik
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      • Vetiundefined
        Veti
        it depends on the sliders you are using.
        the belt path should match the diameter of the pulleys
        Falkiaundefined 1 Reply Last reply Reply Quote 0
        • Falkiaundefined
          Falkia @Veti
          @Veti the printer is under design so the width of the belt path can be chosen but it looks like it will be 18mm
          • Vetiundefined
            Veti
            you will have to make the decision as to what you want.
            16 tooth. lower top speed, higher accuracy compared to 20 tooth.
            on my corexy i use 16 tooth pulley, on my delta i use 20 ( because of the sliders otherwise i would use 16)
              There are several consideratoins:
              • As @Veti says, you should make sure that the rest of your mechanics is compatible with whatever pulley size you choose.
              • Assuming GT2 belts, at x16 microstepping the steps/mm will be 160 using 20 tooth pulleys, or 200 using 16-tooth pulleys. So slightly better resolution per microstep using 16-tooth pulleys (5um) vs 20 tooth pulleys (6.25um). Also, 5um is easier to work with than 6.25um when measuring Z probe trigger heights.
              • The full step resolution will be 100um using 20 tooth pulleys, or 80um for 16-tooth pulleys. Some users prefer to use a layer height that is a whole number of full steps; in which case 100um is easier to work with than 80um.
              • 20-tooth will allow a slightly higher speed than 16-tooth before you run out of either VIN voltage to counter the motor back emf, or step generation rate
              If using 1.8deg motors then I think it's worth using 16-tooth pulleys to get better resolution. With 0.9deg motors, I don't think it makes much difference. I started off using 20-tooth pulleys and 1.8deg motors, then changed to 16 tooth pulleys for better resolution. But then I changed to 0.9deg motors. I still use 0.2mm layer height even though it is not a whole number of full steps.
