    Z calibration offset
    My Duet controlled machine
    959
    • Thunderundefined
      Thunder
      Yes, this is right. Ok, came home and started the machine and a couple of settings were wrong. Now I have managed the home all to touch the probe for z and started the G29 S0
      but I still get the same result. Can anybody point out what I am doing wrong? I am new to programming and this kind of setup.
      System
      My Printer
      g29 s0
      Status
      Busy
      Tool Position
      X
      346.4
      Y
      320.2
      Z
      7.15
      Extruder Drives
      Drive 0
      0.0
      Speeds
      Requested Speed
      3 mm/s
      Top Speed
      3 mm/s
      Sensors
      Vin
      12.0 V
      MCU Temperature
      28.4 C
      Fan RPM
      0
      Z-Probe
      0
       Tools
       Extra
       Control All
      Tool	Heater	Current	Active	Standby
      Tool 0
      T0 - Load Filament	Heater 1
      off	16.9 C
      0
      0
      Bed	Heater 0
      off	18.2 C
      0
      0
      Temperature Chart
      System Directory
      0:/sys/config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 24 2020 20:05:38 GMT+0200 (Central European Summer Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"My Printer"                                 ; set printer name
      M551 P"GoBevk"                                     ; set password
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X160.00 Y80.00 Z800.00 E837                   ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X1400 Y1700 Z1400 E800 I50                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S50                                       ; Set idle timeout
      ;Bl-touch heaters
      M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X500 Y500 Z500 S0                             ; set axis maxima
      M574 X1 Y1 S1;                                   ; set active high endstops
      M574 Z1 S2;
      M558 P9 H5 F500 T4000 X0 Y0 Z1                     ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-66.4 Y-10.2 Z2.15                       ; set Z probe trigger value, offset and trigger height
      M557 X70:433.6 Y70:498.8 S30                           ; define mesh grid
      M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sun Sep 15 2019 21:01:39 GMT+0200 (Central European Summer Time)
      G91 ; relative positioning
      G1 S1 X-500 Y-500 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 S1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X250 Y250 F6000 ; go to first bed probe point and home Z
      G1 S2 Z20 F100 ; lift Z relative to current position
      Thanks in advance 🙂
      • Thunderundefined
        Thunder
        And here is the picture 🙂
        • fcwiltundefined
          fcwilt
          @Thunder said in Z calibration offset:
          For now that G1 command above is OK but it doesn't take into account the z probe X and Y offsets - so you're getting close to the center of the bed but you're not at the center.
          You have to be sure that G30 is setting the Z co-ordinate correctly before G29 will work as desired.
          So do the following:
          After the G30 in homeall.g comment out the G91 and the G1 commands.
          Run homeall.g and see what the Z co-ordinate readout in the DWC is after the execution of G30.
          Verify that it is correct either by measuring the gap between the nozzle and the bed OR jog down to Z=0 and see if the nozzle is just touching the bed.
          Let me know what you find.
          • Thunderundefined
            Thunder
            Ok, I have now managed the calibration. But when I start the program from the slicer I get the Error: M375: Heightmap file bareplate.csv not found I think this means my startup code is not ok
            thank you 🙂
            • fcwiltundefined
              fcwilt @Thunder
              @Thunder
              Well you must have a command somewhere like this G29 S1 P"bareplate.scv".
              For that to work at some point you would have to created that file with G29 S3 P"bareplate.csv".
              Did you do so?
              Thunderundefined 1 Reply Last reply Reply Quote 0
              • Thunderundefined
                Thunder @fcwilt
                @fcwilt
                Ok i checked and you are right. In the startup i had a M375 command. I deleted the line and replaced the command with G29 S1. And now my next question if load the g code of a part for printing the machine homes and makes the printer use the height map that i did eariler with G29 S0. But my nozzle is stil a few 0.1 mm from build plate. Do i correct this with baby steps ?
                Thanks for all of your input 🙂
                • fcwiltundefined
                  fcwilt @Thunder
                  And now my next question if load the g code of a part for printing the machine homes and makes the printer use the > height map that i did eariler with G29 S0. But my nozzle is stil a few 0.1 mm from build plate. Do i correct this with baby
                  Refresh my memory please.
                  When creating the height map do you have commands something like these:
                  G90
                  G1 Xaaa Ybbb ; move the z probe to the center of the bed
                  G30          ; set the Z=0 datum
                  G29          ; probe the bed and create the height map
                  When loading the height map do you have commands something like these:
                  G90
                  G29 S1       ; load the height map
                  • Thunderundefined
                    Thunder @fcwilt
                    @fcwilt
                    Yes like the last one, this code is in slicer start program.
                    • fcwiltundefined
                      fcwilt @Thunder
                      @fcwilt
                      Great.
                      How about when creating the height map?
                      The G30 for creating and loading need to use the exact same X and Y position.
                      • Thunderundefined
                        Thunder
                        Do you mean in the home all section? Sorry I am a little slow when programing 🙂
                        • fcwiltundefined
                          fcwilt @Thunder
                          I don't know where you create the height map.
                          I have a pair of files that I created called mech_comp_map_create.g and mesh_comp_map_load.g.
                          The first is invoked from a DWC macro as I create the height map manually.
                          The second is invoked from another file that I created called print_begin.g which is invoked by the slicer at the start of a print.
                          The essential commands in mech_comp_map_create.g are below
                          G90
                          The essential commands in mech_comp_map_load.g are below
                          G90
                          The important thing to notice is that G30 must be used before creating (G29) or loading (G29 S1) the height map.
