    Multiple problems
    Using Duet Controllers
    1.3k
    • TomasLundefined
      TomasL
      Ok, here it is;
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Feb 05 2021 18:34:18 GMT+0100 (centraleuropeisk normaltid)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Frankenstein"                               ; set printer name
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z500.00 E420.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X18 Y10 Z5 S1                                 ; set axis minima
      M208 X205 Y235 Z190 S0                             ; set axis maxima
      M574 X1 S1 P"^xstop"                               ; configure active-high endstop for low end on X via pin ^xstop
      M574 Y1 S1 P"^ystop"                               ; configure active-high endstop for low end on Y via pin ^ystop
      M574 Z1 S1 P"^zstop"                               ; configure active-high endstop for low end on Z via pin ^zstop
      M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X29 Y0 Z2.5                               ; set Z probe trigger value, offset and trigger height
      M557 X33:200 Y25:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      Home All
      ; homeall.g
      ; called to home all axes
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-192 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-192 Y-230 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-190 F360        ; move Z down stopping at the endstop
      G90                     ; absolute positioning
      G92 Z5                  ; set Z position to axis minimum (you may want to adjust this)
      ;G91                    ; relative positioning
      ;G1 Z5 F100             ; lift Z relative to current position
      ;G90                    ; absolute positioning
      homex.g
      ; homex.g
      ; called to home the X axis
      G1 H1 X-228 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000    ; go back a few mm
      G1 H1 X-228 F360  ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000   ; lower Z again
      homey.g
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-250 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000    ; go back a few mm
      G1 H1 Y-250 F360  ; move slowly to Y axis endstop once more (second pass)
      homez.g
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z-200 F1800 ; move Z down until the endstop is triggered
      bed.g
      G29  ; probe the bed and enable compensation
      • fcwiltundefined
        fcwilt
        @TomasL said in Multiple problems:
        Thanks - looking at them now...
        M208 X18 Y10 Z5 S1 - Z5 is a very odd value - normally the value is 0 or a bit less.
        Please explain.
        • TomasLundefined
          TomasL
          Another problem I have is that when I do the motor test macro, randomly it says that one phase is missing on the motors.
          Allways on the extruder thoug.
          I have measured the connection and everything seems to be ok, connectionwise, i.e there is no open circuit or any short circuit.
          • TomasLundefined
            TomasL
            What is M208?
            fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
            • TomasLundefined
              TomasL
              I guess that is the offsets from the limitswitches.
              Well, when the X-switch is activated, the head is around 18mm out of the bed, same with the Y-switch, the Z I had set just to avoid it craching into the glass. for the moment.
              Maybe I got it the wrong way around
              • fcwiltundefined
                fcwilt @TomasL
                What is M208?
                Another "victim" of the configuration tool - it has shielded you from learning the commands.
                M208 is used to set the axes minimum and maximum positions.
                For example on one of my printers I have this: M208 X-150:150 Y-100:100 Z0:300.
                What is means is the range on...
                • the X axis is from -150 to +150
                • the Y axis is from -100 to +100
                • the Z axis is from 0 to 300
                • alankilianundefined
                  alankilian @TomasL
                  @TomasL It's just FINE that you are confused and having problems.
                  We're here to help you and we will get you going eventually. We've all been confused with this stuff also.
                  Stay POSITIVE and you';ll get the best results from this group.
                  You can look up all the G and M codes here.
                  Here's M208
                  So, let's start with this:
                  • Move the carriage away from the X, Y and Z limit switches and post the result of M119
                  • Press the X limit switch and post the result of M119. Release the X limit switch.
                  • Press the Y limit switch and post the result of M119. Release the Y limit switch.
                  • Press the Z limit switch and post the result of M119. Release the Z limit switch.
                  This will show that each limit switch is hooked up correctly and working correctly.
                  Then we can move on to homing.
                  • fcwiltundefined
                    fcwilt @TomasL
                    OK that value for Z then makes sense as it is only for testing.
                    Can the end stop switches be adjusted can reach the edges of the printable area?
                    • fcwiltundefined
                      fcwilt @TomasL
                      What motor test macro? Was it on the SD card? If it is the same as my SD card that macro is for factory use.
                      • TomasLundefined
                        TomasL
                        Ok, Ill have to do that tomorrow, since the printer is in my lab and I am at home , by the way, this is my labWP_20200916_21_02_34_Pro (1).jpg
                        Yes, the macros show upp in the WEB-UI
                          alankilian @fcwilt
                          @fcwilt said in Multiple problems:
                          OK, then in M208, you want X-18 instead of X18
                          Then, in homex.g the command on line #9 G1 H1 X-228 F360 says to move in the negative direction until the endstop switch is hit, and THEN set the current X location at minus-18mm which is what I think you want.
                          So a similar thing for Y and Z
                          • fcwiltundefined
                            fcwilt @TomasL
                            @TomasL
                            I see the problem.
                            You don't own enough test equipment.
                            Are those scopes Tektronix? What models?
                              Any macros that came on the SD card should not be run. They are for factory testing. These macros are no longer included, but boards that were purchased before the change may still have them.
                                alankilian
                                Nice lab!
                                • TomasLundefined
                                  TomasL
                                  If I am allowed to do som "commercials",
                                  I run two sites, (well three sites really).
                                  They might be usefull, since all information is free.
                                  The first site is ebaman.com, where I collect users/service manuals and other documents, for full free download, the only catch is that you have to register to download.
                                  I have the largest collection of Heathkit manuals available, plus some 13k of other manuals.
                                  My next site is ba-restore.com, dedicated for restoring boat-anchors (well for you that dont know what it is, old electronic and mechanical equipment).
                                  The third site, is microdiscray.com basically this site describe how crazy I am, since my intention is to build a MIPS32 CPU/Computer in discrete components based on ECL-technology.
                                  When I'll get some $10k or so available, I would probably build it.
                                  Anyway, I am happy for all help I could get
                                  • TomasLundefined
                                    TomasL
                                    Well, the Lab
                                    Right, what do I have in there, well:
                                    One TEK 7854 computing mainframe with calculator.
                                    One TEK 7603 with 7D20 Digitizer
                                    One TEK 7613 Storage with Curve tracer
                                    A number of various TEK7000 series Plug-Inns
                                    One Nicolet 4094 Storage scope with dual 5 1/4 Floppy-Drive.
                                    One TEK DPO7000
                                    One HP 2GHz spectrum analyzer
                                    One Agilent 6,5 digit DVM
                                    One Fluke 8854a 5,5 Digit DVM
                                    One fluke 8000 DVM
                                    Various fluke handhelds
                                    One handheld Agilent LCR-meter
                                    One TEK 1241 96 channel Logic analyzer
                                    One TEK 308 8-bit +16- bit Logic analyzer
                                    One HP Counter
                                    One TM500 with a number of various modules
                                    3 weller WX soldering stations, 40, 80 and 200W
                                    1 Weller De-solderiong station
                                    One Hot air soldering station
                                    2 Leica Stereo microscopes with lightassembly
                                    One 3-d Printer
                                    And to finilize the whole stuff, one complete SMD Pick and Place assembly line
                                    • TomasLundefined
                                      TomasL
                                      Fredrick, I know, I need to get some more stuff.
                                      On the purchace list is a Wow&Flutter meter amongst others.
                                        alankilian
                                        I worked at Cray Research Inc for 16 years, so I know "Seymour" Cray's work well.
                                        If you don't like integrated circuits like he used in the Cray-1, try looking at his previous machine, the CDC 6600. It's all transistors!
                                        • TomasLundefined
                                          TomasL
                                          alankilian, will certainly do, however, the thing is, I can DO IT.
                                          • fcwiltundefined
                                            fcwilt @TomasL
                                            One TEK DPO7000
                                            Thought some things looked familiar.
                                            My company, many many years ago, sold an interface between the HP 9830 Desktop Calculator and the DPO.
                                            We also had an interface from the 9830 to the Tek computer terminals that used their CRT storage technology.
                                            Ah... the good old days when the Z80 microprocessor was "hot stuff".
