Duet controlled D-bot
My Duet controlled machine
1.2k
    derfred
    Hi!
    Just want to thank you for this great board and firmware. I won´t buy anything else, thats for sure 🙂
    This is my new Duet controlled D-bot and its first prints:
    https://youtu.be/FNpUPsU4HUs
    The retraction, xy jerk, speeds and accelerations were not set yet.
    And this one with the machine printing a bottle in spiral mode with all the settings set the best I could to date:
    https://www.youtube.com/watch?v=KRwMe1WBOjI
    And another one in layer by layer print mode:
    https://youtu.be/BoFTS9AjwV0
    Has anyone developed printer farm control panel for the Duet? Something simple like showing on one single webpage the temperatures, status, remaining time or progress and file name of the files being printed on each machine?
      Whitewolf
      probably not considering its easy to accomplish that with a browsers tabbing feature thats already implemented by default though it does require switching between tabs. A Dashboard could be designed but would most likely be best served from a RPI or web server.
        derfred
        The idea is to have a view on multiple machines at the same time. The web control panel is all on javascript and I fnd javascript very confusing and I don´t quite know it, even so I´ll have a look at how the information is pulled from the machine.
        The ww folder on my sdcard only has a .gzip file, not an html as the index page, is this .gz file generated by the app or was just put there in that form?
        May I replace the whole www contents by the unzipped files from the github repository?
          Yes you can use the unzipped versions instead if you delete the gzipped versions. But they will take longer to load.
            whosrdaddy
            You can run the webpage from your computer, it will ask to which printer it has to connect.
            It wouldn't be to hard to make a multiprinter version…
              derfred
              Thank you all for the answers and ideas.
              1 out of 6
