    Question about Duet2Maestro external drive module
    Using Duet Controllers
    1.1k
    • ansonyangundefined
      ansonyang
      I want to replace the TMC2224 on the motherboard with other drive modules
      • Vetiundefined
        Veti
        you want to desolder the onboard drivers?
        at that stage it might be easier to get a skr board and run the lpc port of rrf on it
        ansonyangundefined 1 Reply Last reply Reply Quote 0
          ansonyang @Veti
          @Veti I don't know, can you tell me?
          • Vetiundefined
            Veti
            see
            https://github.com/sdavi/RepRapFirmware
              ansonyang @Veti
              @Veti Thank you my friend
                ansonyang
                • Vetiundefined
                  Veti
                  why would you want to use a drv8825 instead of a tmc driver?
                    ansonyang @Veti
                    @Veti I want to use a big drive to drive a big motor, not just DRV8825
                    • Vetiundefined
                      Veti
                      the duet 3 can drive up to 6.3A
                        ansonyang
                        The price of DUET3 is beyond my ability.
                        I like DUET2MAESTRO very much, but TMC2224 is not what I want, I want more flexible drive support
                        • Vetiundefined
                          Veti
                          it makes no sense to buy a maestro and replace the drivers.
                          one of these ports with the port makes more sense.
                          https://teamgloomy.github.io/supported_boards.html
