PID Hotend Autotune - How Long?
So it takes hours?
@Adamfilip said in PID Hotend Autotune - How Long?:
So it takes hours?
look at the temperature graph it should go up and down
Looks solid.
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
Duet WiFi Server Version: 1.25 -
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 ; Map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4 ; disable bang-bang mode for the nozzle heater and set PWM limit M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S285; set temperature limit for heater 1 to 280C M307 H1 A310.2 C150.5 D3.5 B0 S1 v24.3 ;NEW
that may be one for @dc42
Tried again,
Fine until it reaches Phase 3 with Fan on,
Fan is working at 100% but temp does not cycle -
Photo of your hotend? It may be expecting to see a drop from the fan, but it's not happening.
Does it matter what idle temp the hotend is before you start this?
It should be from ambient.
My Cooling is excessive when turned onto full, that's why I'm doing to Autotune as I had a 15 degree drop and It faulted during my last print
Are you controlling the fan yourself during the tune with M303 T0?
You should leave the fan off and the firmware will turn it on when needed.
I not manually controlling it. it was set to off and nozzle temp was ambient last time I tried (running now.. 1.5hrs in so far)
You're tuning to 220 and it's steady at 218. Try tuning to 215.
ok will attempt
is there way to limit power to fan so 100% is just actually 50% power?
M950 F0 C"fan0" Q100
When you configure the fan in config.g using m106, use the "X" parameter. For example, M0.5 will tell RRF that when the fan is set to 100% via "M106 S1" (or M106 S255), it actually only runs at 50%.
When I ran M303 T0 S215
I finally got this resultWarning: heater behaviour was not consistent during tuning
Auto tuning heater 1 completed after 3 idle and 30 tuning cycles in 4475 seconds. This heater needs the following M307 command:
M307 H1 R1.621 C180.9:140.4 D7.18 S1.00 V24.1
Edit the M307 H1 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN. -
How does the heater perform with those values?
