    Jumper for ZB Duet 2 Wifi
    • Tpmosesundefined
      Tpmoses
      Hello all,
      I am looking to separate the drives for the Z Motors on a printer I inherited at work. The person who built it used both Z ports for the Motors, and threw out the jumpers that came with the board on Zb. My question is where can I buy new jumpers for that port? Any help would be greatly appreciated,
      Thanks,
      -T
        If you wanted to buy some you could probably find them locally at a electronics place.
        If you have a dupont connector you could make your own jumpers with a piece of wire.
        if you google computer jumper you can find a lot of them. Not sure where you are so can't really recommend any place in particular.
        • alankilianundefined
          alankilian
          It just take 2 two-pin jumpers.
          I can mail them to you if that's best.
          Otherwise, find any old computer motherboard and you can find them on there I bet.
          • Tpmosesundefined
            Tpmoses
            Ordered the connectors, Thank you!
