    firmware retraction doubling
    Gcode meta commands
    1.2k
      If you send M207 during a print, what does it reply with?
      • nanoplaneundefined
        nanoplane
        So... This is interesting..
        I have no config-override.g file in my /sys directory but after I sent an M502 command, G10/G11 worked as expected.....
        Is this a hidden file?
          deckingman @nanoplane
          @nanoplane said in firmware retraction doubling:
          IIRC, M3D used to do very strange things with their configuration files. Basically they used to break each section into a separate macro and then call each of those macros from within the config.g file. Is that how yours is set up? If so, it's likely that the changes you make to config.g could be overridden by later macros. I might be best if you post you config.g file and the full code of any macros that are referenced in that file.
          nanoplaneundefined 1 Reply Last reply Reply Quote 0
            nanoplane @deckingman
            @deckingman
            it was for the 2.0 config, but for the 3.0 update I put everything in the one file. It loads with no errors, but I suspect maybe there was some override file hidden somewhere that had a different M207 command hidden in it??
              nanoplane
              So, it all seems to be working now... not quite sure what happened, but...
              Thanks everyone who looked at this and scratched their heads...
              --marcel
              • OwenDundefined
                OwenD
                M98 PPrint_Start.g
                Should be quoted
                M98 P"Print_Start.g"
                  nanoplane
                  Thank you.
                  One more question. does the M207 command need to be sent after the tools are all created?..
                  I'm still getting the issue that the retract gets reset to 2mm whenever I start a new print from the "initial" state.
                  my custom gCode for PrusaSlicer at start creates the per color tools and after they start being used M207 command returns 2mm for retract amount even though I'm setting it in the config file to 0.5mm
                    Please share your full config.g you slicer start gcode and any macros you call in it.
                    Also the results of M122 and M98 P"config.g" please.
                    nanoplaneundefined 2 Replies Last reply Reply Quote 0
                      nanoplane @Phaedrux
                      @Phaedrux
                      config.g
                      Starting gCode from Prusa Slicer:
                      M190 S[first_layer_bed_temperature] ; wait for first layer bed temperature
                      G28 ; home all axes
                      ;G29 ; Auto Bed Leveling...
                      M104 S[first_layer_temperature] ; Heatup and Purge Nozzle
                      G92 E0 ; reset extruder
                      G1 X0 Y0 Z10.0 F5000 ; move to purge position
                      T0
                      ; bring it up to temperature
                      G10 P0 R0 S[first_layer_temperature] ; Wait For Nozzle Heat
                      M116
                      ; machine standard purge - purges all nozzles on the left side of the platter.
                      ; set up the tools for selected colors.. You can define as many as you want,
                      ; just make sure you update their temperatures in the Before layer change G-Code and remove them in the End G-Code
                      M563 P0 D0:1:2:3 H1 F1
                      M563 P1 D0:1:2:3 H1 F1
                      M563 P2 D0:1:2:3 H1 F1
                      M563 P3 D0:1:2:3 H1 F1
                      ;=============== Quad Fustion color support ===============
                      ;Set the color for each of the defined "tools"
                      M567 P0 E1.0:0.0:0.0:0.00 S"Cyan"
                      M567 P1 E0.0:1.0:0.0:0.00 ; Magenta
                      M567 P2 E0.0:0.00:1.0:0.00 ; yellow
                      M567 P3 E0.0:0.0:0.0:1.0 ; White
                      ;Init the tool temperatures for the first layer and wait.
                      G10 P1 R0 S[first_layer_temperature]
                      G10 P2 R0 S[first_layer_temperature]
                      G10 P3 R0 S[first_layer_temperature]
                      M116
                      T0 ; Ensure Post Processing Gcode Generator Has something to convert if only one tool is used.
                        nanoplane @Phaedrux
                        @Phaedrux
                        Also at the end of a print, custom gCode is:
                        ; remove the extra tools so we restore back to standard
                        M563 P3 D-1 H-1
                        M563 P2 D-1 H-1
                        M563 P1 D-1 H-1
                        M104 S0 ; turn off temperature
                        G28 X0 ; home X axis
                        M140 S0
                        M84 ; disable motors
                          What's in M98 PPrint_Start.g?
                            nanoplane @Phaedrux
                            @Phaedrux
                            print_start.g
                              If you send M98 Pprint_start.g on it's own do you get any errors?
                              If you send M567 during the print does it respond with the expected mixing ratio?
                              Have you enclosed the macro name in quotes as OwenD suggested? ""
                                nanoplane @Phaedrux
                                @Phaedrux said in firmware retraction doubling:
                                I get no errors
                                Hmm sending M567 returns nothing... But it does mess up the mix ratio for the current print.. until the next tool changes.
                                sending M567 P0 (P1 P2 P3) returns the correct mix ration for each of the "tools"
                                The print_start.g on it's own doesn't work unless I've preheated the bed and the nozzle... but once that's done, print_startg works fine.
                                Could it be because I'm redefining Tool 0 in my custom gCode forcing it to default the retraction settings??
                                  nanoplane
                                  Yep, that's it....
                                  Recreating or adding a new tool sets the retraction to a default value of 2mm..
                                  So I need to add an M207 S0.5 F1000 Z0.2 command to my custom gCode after creating all the tools...
                                  cool.
                                    Glad you figured it out.
                                      nanoplane
                                      It's a feature 🙂
