    Tool position not updated 3.2.9
    PanelDue
    1
    • Phil Maddoxundefined
      Phil Maddox
      Hi
      I have an issue that the tool position isn't being updated in the "move" screen. I found the same with 3.2.7
      Other than that the machine works great.
      I used to use the move page to evaluate my Z offset and it was handy to be able to home all then move Z down to it print height and see how things were in comparison to the Z offset set in config.g
      X & Y are not updated either
      The axis position are also not updated on the main screen either
      Tool position is updated instantly & correctly in DWC
      Machine:
      Cartesian i3 steel 2.5
      Duet Wifi 2
      Panel Due 4.3
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      Duet Web Control 2.0.4
        Phil Maddox
        Update . Just re flashed everything from scratch and now appears to work! Panic over
        • mfs12undefined mfs12 marked this topic as a question
        • mfs12undefined mfs12 has marked this topic as solved
