    z axis squashed?
    564
    • Scally123undefined
      Scally123
      Hi both thanks for your replies,
      So I centred the nozzle on the print bed and told the bed to move 50mm, 100mm, and 150mm and measured the total distance travelled,
      • when told to move 50mm it moved 49.75
      • when told to move 100mm it moved 99.72
      • when told to move 150mm it moved 149.79
      this seems to me that it only gains 0.5mm every 10mm when printing. I am using Cura 4.5. Do you believe it may be a setting within Cura I've messed up somewhere?
      Thanks for all your help
      • fcwiltundefined
        fcwilt @Scally123
        @Scally123 said in z axis squashed?:
        M579 exists for a reason. Try it and see if it solves your problem.
        Scally123undefined 1 Reply Last reply Reply Quote 1
          Scally123 @fcwilt
          Apologies @fcwilt I am bit unsure on what to do.
          I have entered M579 X Y and Z axis factors are at 1.
          Do I have to change the axis factors for the z-axis prior to printing?
          Thanks for your help
          • fcwiltundefined
            fcwilt @Scally123
            Consider your measurement of a command to move 100mm that only moved 99.72mm.
            You didn't say what axis that was but lets say it was X.
            So 100.00 / 99.72 = 1.003 (rounded up to thee decimal places)
            So you would add a M579 command to your config.g file that looks like this...
            M579 X1.003 Y1.0 Z1.0
            ...and reboot your printer to cause the command to take effect.
            You would determine the values for Y and Z in the same way - command a movement and measure the result.
              Scally123 @fcwilt
              @fcwilt ooooh I think I understand. I'll try that now.
              Sorry for confusing things a little. Just for clarification, the 3 measurements taken were all on the Z-axis when I moved the bed down by 50, 100, and 150mm. I just thought it was odd that when simply moving the bed down it was out by 0.25mm ish no matter how far it went.
              Whereas when I print it was out by approximately 0.5mm when printing a 10mm high object and about 1mm out when printing a 20mm high object as if the discrepancy was increasing with the increase of the printed objects height.
              I'll add the M579 to the Config and print this afternoon.
              Thank you for your help
              • fcwiltundefined
                fcwilt @Scally123
                That is odd. I cannot imagine what could cause that.
                That is the sort of problem M579 can help with.
                • alankilianundefined
                  alankilian
                  There is no difference between you typing in G1 x0 y0 z100 and a file with a G1 x0 y0 z100 while printing.
                  There's still something wrong.
                  Personally, I would figure out what the problem is rather than patch over it with an M579.
                  ESPECIALLY on a leadscrew Z-axis printer where there should be no need for a patch like this.
                  Can you post the GCODE from a simple 1-wall box for us to take a look at?
                    Scally123
                    ; Configuration file for Duet Maestro (firmware version 1.21)
                    ; generated by RepRapFirmware Configuration Tool v2 on Sun Jun 16 2019 12:10:53 GMT+0100 (British Summer Time)
                    ;AXIS SCALING
                    M579 X1.0 Y1.0 Z1.055
                    M550 P"" ; Set machine name
                    M551 P"" ; Set password
                    M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P0 S1 ; Physical drive 0 goes forwards
                    M569 P1 S0 ; Physical drive 1 goes forwards
                    M569 P2 S1 ; Physical drive 2 goes forwards z
                    M569 P3 S0 ; Physical drive 3 goes forwards
                    M92 X80.00 Y80.00 Z2560.00 E92.60 ; Set steps per mm
                    M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
                    M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                    M906 X950.00 Y950.00 Z950.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X200 Y200 Z190 S0 ; Set axis maxima
                    M574 X1 Y1 Z1 S1 ; Set active low and disabled endstops
                    M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
                    G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                    M557 X15:185 Y15:185 S20 ; Define mesh grid
                    M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                    M305 P0 X500 R2200 ; Configure PT1000 for heater 0
                    M305 P1 X501 R2200 ; Configure PT1000 for heater 1
                    M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 ; Define tool 0
                    ; Automatic power saving
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      Scally123
                      I've just printed a 20mm test cube after adding M579 but it is 21mm high now.
                      • fcwiltundefined
                        fcwilt @Scally123
                        Where did you get that Z1.055 value?
                        The data that I used in my example came from your Z axis but for my example I assumed X.
                        The math is the same in either case and the value I came up with was 1.003 which is a good deal smaller than 1.055.
                        Using the size of the cube at 21 we can adjust the value.
                        1.055 * (20 / 21) = 1.004 which is close to the 1.003 that I came up with.
                        So just keep adjusting the value until you get the desired results.
