    Duet 2 Maestro occasionally stops mid print
    865
    • Infinitysnekundefined
      Infinitysnek
      I recently updated to RRF3 and occasionally it stops mid print and ends the job. When I run the same gcode again it just prints fine.
      Today it happend twice on different gcode and with successful prints in between. The M122 shows nearly identical results (included below).
      Since it happend after updating I suspect I maybe made an error in the config.g. What would be the best way to find these?
      M122
      RepRapFirmware for Duet 2 Maestro version 3.2 running on Duet Maestro 1.0
      Board ID: 08DJM-956DU-LLMS4-7JTD6-3SS6L-KVLUR
      Used output buffers: 3 of 24 (10 max)
      Static ram: 22292
      Dynamic ram: 73128 of which 24 recycled
      Never used RAM 19388, free system stack 214 words
      Tasks: NETWORK(ready,204) HEAT(blocked,340) TMC(blocked,117) MAIN(running,477) IDLE(ready,20)
      Owned mutexes:
      Last reset 00:05:38 ago, cause: software
      Last software reset at 2021-02-13 11:38, reason: StuckInSpinLoop, GCodes spinning, available RAM 19352, slot 2
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x2000437c Task MAIN Freestk 797 ok
      Stack: 0041e471 004555e2 610f0000 00000000 00000001 0041da55 00004009 00000001 e000ed04 20000c68 00000001 00004009 00000001 20000c68 0041e763 00000001 00000001 00000000 0041eedd 00000000 00000001 200045dc 00f07fff 00000000 20000c30 00004009 20000e48
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 19.7, current 20.1, max 21.2
      Supply voltage: min 0.0, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 21, reads 56346, writes 8, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 21, reads 56346, writes 8, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 21, reads 56346, writes 8, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 21, reads 56346, writes 8, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 13, reads 56348, writes 6, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-02-13 11:44:13
      Slowest loop: 74.25ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest read time 1.4ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 5.57ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      M122
      Static ram: 22292
      Tasks: NETWORK(ready,206) HEAT(blocked,334) TMC(blocked,117) MAIN(running,468) IDLE(ready,20)
      Owned mutexes:
      Last reset 00:02:09 ago, cause: software
      Last software reset at 2021-02-13 15:10, reason: StuckInSpinLoop, GCodes spinning, available RAM 19352, slot 0
      Stack: 0041e471 004555e0 610f0000 00000000 00000001 0041da55 00004181 00000001 e000ed04 20000c68 00000001 00004181 00000001 20000c68 0041e763 00000001 00000001 00000000 0041eedd 00000000 00000001 2000448c 00f07fff 0000000f 20000c30 00004181 20000e48
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 21.2, current 21.7, max 22.4
      Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 26, reads 21594, writes 8, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 26, reads 21594, writes 8, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 28, reads 21594, writes 8, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 26, reads 21594, writes 8, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 13, reads 21596, writes 6, timeouts 0, DMA errors 0
      Date/time: 2021-02-13 15:12:32
      Slowest loop: 73.97ms; fastest: 0.17ms
      === Storage ===
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Aux is idle in state(s) 0
      === Network ===
      Slowest loop: 5.21ms; fastest: 0.02ms
      Interface state active, link 100Mbps full duplex```
      [0_1613229063924_config.g](Uploading 100%)[config.g](/assets/uploads/files/1613229649410-config.g)
      • Vetiundefined
        Veti
        can you post your config.
          Infinitysnek
          I tried to include it but it aperantly didn't show up.
          Does it work now?
          config.g
          • Vetiundefined
            Veti
            dont see anything in there that could cause that.
            however your second thermistor setting is incorrect
            M308 S2 P"e1temp" Y"thermistor" T100000 B4092 C7.06e-8 ; define enclosure temperature sensor
            either its an semitec then your b value is incorrect or its not and you put in C by mistake
            Infinitysnekundefined 1 Reply Last reply Reply Quote 0
              Infinitysnek @Veti
              I think I forgot to remove that after I copied the first thermistor.
              If the config is fine do you know what steps I could take to figure out why it randomly stops?
              • Vetiundefined
                Veti
                can you try 3.2.2? there were some sd card fixes that dc42 caused StuckInSpinLoop.
                  Infinitysnek
                  Just updated to 3.2.2. I'll probably find out tomorrow if it fixed the issue
                    Infinitysnek
                    Im on 3.2.2 now and it suddenly stopped again. This time not during a print but during the auto bed leveling. Does that rule out the sd card causing issues?
                    M122
                    RepRapFirmware for Duet 2 Maestro version 3.2.2 running on Duet Maestro 1.0
                    Used output buffers: 1 of 24 (10 max)
                    Static ram: 22284
                    Never used RAM 19396, free system stack 206 words
                    Tasks: NETWORK(ready,206) HEAT(blocked,341) TMC(blocked,117) MAIN(running,478) IDLE(ready,21)
                    Owned mutexes:
                    Last reset 00:15:27 ago, cause: software
                    Last software reset at 2021-02-15 17:22, reason: StuckInSpinLoop, GCodes spinning, available RAM 18992, slot 0
                    Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x200042cc Task MAIN Freestk 754 ok
                    Stack: 0041e60b 00455812 610b0000 00000000 00000000 20002858 00000001 00000001 00000014 7f61294e 20000c68 00000001 00000000 00000001 20000c68 00000028 7f62712c 200028cc 0041e9f1 00000001 00000000 00004184 0041f171 20000c68 00000001 7f5e9f7b 00f07fff
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 19.4, current 20.0, max 21.0
                    Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 23, reads 23427, writes 8, timeouts 0, DMA errors 0
                    Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 23, reads 23427, writes 8, timeouts 0, DMA errors 0
                    Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 25, reads 23427, writes 8, timeouts 0, DMA errors 0
                    Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 22, reads 23427, writes 8, timeouts 0, DMA errors 0
                    Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 13, reads 23429, writes 6, timeouts 0, DMA errors 0
                    Date/time: 2021-02-15 17:38:44
                    Slowest loop: 72.61ms; fastest: 0.17ms
                    === Storage ===
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 6.40ms; fastest: 0.02ms
                    • Vetiundefined
                      Veti
                      @dc42 can you have a look at the stacktrace?
                        Can you post your full config.g and the results of M98 P"config.g" ?
                        And maybe a sample gcode file that has caused the crash?
                        Vetiundefined Infinitysnekundefined 2 Replies Last reply Reply Quote 0
                        • Vetiundefined
                          Veti @Phaedrux
                          @Phaedrux
                          the config is above
                            Infinitysnek @Phaedrux
                            @Phaedrux
                            Would the gcode be helpful? It doesn't consistently happen even with running the same file again. The last one happend during a mesh level command
                            M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 463C
                              Phaedrux Moderator @Veti
                              @Veti said in Duet 2 Maestro occasionally stops mid print:
                              @Phaedrux
                              the config is above
                              Ah yes, missed the link.
                              @Infinitysnek said in Duet 2 Maestro occasionally stops mid print:
                              In that case, probably not.
                                In all three M122 reports that you provided, the microcontroller was stuck waiting for an SD command to complete. So I have these suggestions:
                                • Replace the SD card
                                • Firmware 3.2.x reads the SD card more often than older firmware because it supports the daemon.g process. If you are not using daemon.g, create a daemon.g file in /sys containing this single command:
                                G4 S100000
                                That will put the daemon task to sleep for almost a month at a time.
                                  Infinitysnek @dc42
                                  @dc42 Thank you for looking in to this.
                                  I made the daemon.g file, does that run automatically on startup or do I need to do something once a month?
                                  I'll wait for a new SD card to arrive tomorrow.
                                    The daemon.g file runs automatically at startup, so just having the file present is sufficient to put it to sleep.
                                      PS - are you running your prints from the internal SD card in the Duet, or are you using an external SD card socket?
                                        Infinitysnek @dc42
                                        @dc42 All from the internal SD card. I upload everything via the web interface. I don't have an external SD card socket.
