    G1 Issues
    749
    • fcwiltundefined
      fcwilt @Pierre52
      @Pierre52 said in G1 Issues:
      @fcwilt thanks for the input. I'll give that a try.
      Still looking to resolve the no move without M564 tho
      Well in the code I commented about you were twice attempting to move un-homed axes.
      The M564 allows you to do this but you really should not have to use M564.
      Did you try the changes I mentioned?
      • Pierre52undefined
        Pierre52
        @Phaedrux "Tune your sensitivity" Sorry but you have just exceeded my level of expertise.
        • Pierre52undefined
          Pierre52
          @fcwilt Apologies Frederick but I was tied up with a bunch of other stuff yesterday.
          I added H2 to the G1 command (what does H2 actually do as it doesn't feature in the RepRap decode?).
          With H2 added the Home All command now starts the sequence but when the closest of x or y is reached the procedure stops at the end of this line in Homeall:
          G1 H1 X-325 Y-325 F3600 ; move right/back 325mm, stopping at the endstop
          More confusing, If Y is closest to home then the procedure stops as above with Y homed but the Dashboard shows X is homed but Y isn't.
          • fcwiltundefined
            fcwilt @Pierre52
            Something is wrong.
            I don't normally home X and Y at the same time but to be sure I understood the behavior I modified by homeALL.g file to do so
            This is what I did (the numbers are for my printer)...
            G91                   ; relative moves
            G1 H1 X210 Y-210 F1200; 1st pass - this moved until BOTH endstops were triggered
            G1 X-20 Y+20          ; back off a bit
            G1 H1 X30 Y-30 F300   ; 2nd pass - this also moved until BOTH endstops were triggered
            If your are endstops are configured correctly and are working that is all you should need to do to home X AND Y.
            I did not show any code to move Z - just wanted to focus on X and Y.
            HOWEVER you are using stalling to home - I don't know if that works the same.
            I liken homing with stalling to stopping your car by running into the car in front of you - I prefer using the brakes. 😉
            Frederic
              Phaedrux Moderator @Pierre52
              M915 X Y S2 R0 F0 ; set X and Y to sensitivity 2, do nothing when stall, unfiltered
              You've got a command to configure stallguard, but you'll need to tune the sensitivity and motor current to get reliable movement and stalls.
              https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
              • Pierre52undefined
                Pierre52
                @fcwilt and @Phaedrux apologies for not responding sooner but I have been away for several days.
                I have tried all of your suggestions but seem no closer to solving this. In fact I have been experimenting like crazy will all of the homing files to see if I could even get one of them to work.
                The weirdest thing is that I am currently getting perfect homing on X Y and Z with this Home All file below but using M564.
                Even though I have the same M915, and M574 in Config.G, If I comment them out in this file nothing happens.
                Even more weirdly, Z is homing in the center of the bed even though it is commented out in this version of Home All. I can only presume that the Home Z file is run after this one.
                It also seems that a G91 line after the probe has been triggered stops any further movement command from being executed. I have put the Home Z file below the Home G
                Homeall.g
                M400 ; make sure everything has stopped before we make changes
                M564 S0 H0
                M574 X1 Y1 S3 ; set endstops to use motor stall
                G91 ; use relative positioning
                G1 Z5 F1200 ; Lower bed 5mm
                G1 H1 X-325 F3600 ; Move X to Home
                G1 X5 ; move away from home Left end stop
                G1 H1 Y-325 F3600 ; move Y to home
                G1 Y5 ; move away from home
                G90
                ;homez.g
                ; called to home the Z axis
                ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 22 2021 13:39:52 GMT+1300 (New Zealand Daylight Time)
                M402 ; Retract BL Touch
                G1 Z5 F1200 ; Lower bed 5mm to enure clear of Z Probe
                G90 ; absolute positioning
                G1 X150 Y150 F4000 ; move head to bed center
                G30 ; Lower head, stop when probe triggered and set Z to trigger height
                G91 ; relative positioning
                G1 X0 Y0 F4000 ; Return head to home position
                M400 ; make sure everything has stopped before we reset the motor currents
                G90 ; back to absolute position
                • fcwiltundefined
                  fcwilt @Pierre52
                  That simply makes no sense at all. If the appear in config.g and they have to be duplicated somewhere else then something else you are doing is canceling them out.
                  homeall.g all will not call homeZ.g unless you are doing something in homeall.g that makes that happen - it does not happen on it's own.
                  About homing in general:
                  There are movement commands specifically designed to be used to home the axes in your machine. You need to learn to use them and not just use M564 to allow everything to happen.
                  You can use relative G1 H1 commands to move an un-homed axis towards it's endstop and stop when the endstop is triggered. The endstop can be of any type including "stalling".
                  You can use relative G1 H2 commands to move an un-homed axis as needed to home another axis - such as making sure Z is clear of the bed before homing X or Y.
                  Your homeall.g file:
                   M564 S0 H0
                   G90
                  OK let us discuss your homeall.g file line by line:
                  line 1 is fine
                  line 2 should not be needed if the rest of the file is correct
                  line 3 should be fine if you have the command parameters correct
                  line 4 should be fine if you have the command parameters correct
                  line 5 is fine
                  line 6 is will not work without the M564 above. Use G1 H2 as mentioned.
                  line 7 is fine
                  line 8 is fine but I don't know why you have it
                  line 9 is fine
                  line 10 is fine but I don't know why you have it
                  line 11 is fine
                  Now nowhere in that file did you home Z and it's supposed to be homed in your homeall.g file. Why did you not home Z?
                  Your homez.g file:
                  G1 Z5 F1200           ; lower bed 5mm to enure clear of Z Probe
                  OK let us discuss your homez.g file line by line:
                  line 1 makes no sense you since don't actually change anything that might need it
                  line 2 is not needed as BLTouch probes are deployed/retracted automatically as needed
                  line 3 is fine
                  line 4 will not work as Z may not be homed at this point. Use G1 H2 as mentioned.
                  line 5 is fine
                  line 6 may not work as X or Y may not be homed at this point use G1 H2 as mentioned.
                  line 7 should work - the probe should move toward the bed and stop when activated
                  line 8 is fine
                  line 9 may not work as X or Y may not be homed at this point use G1 H2 as mentioned.
                  line 10 makes no sense you since don't actually change anything that might need it
                  line 11 is fine
                  If you find yourself wanting to use M564 that should be a warning to you that you are very likely doing something wrong.
                  When in doubt - ask us.
                  • Pierre52undefined
                    Pierre52
                    @fcwilt . Than you Frederick I have finally got an explanation of what H2 does in the G90 command. I have been searching for this for ages and your explanations of H1 and H2 above finally made sense of everything. I was also having some fun getting my head around where and when if should be using G90 vs G91.
                    I have now rebuilt my Home all file and everything now works exactly as it should. No need for M594 any more.
                    The working Home all looks like this:
                    M574 X1 Y1 S3 ; set end stops to use motor stall
                    G1 H2 Z5 F1200 ; Lower bed 5mm
                    G90 ; Use Absolute positioning
                    G1 X150 Y150 F4000 ; Move head to center of bed
                    G30 ; Lower Head, Stop when probe triggered and set Z to trigger height
                    G1 X0 Y0 F4000 ; Return Head to Home
                    • fcwiltundefined
                      fcwilt @Pierre52
                      @Pierre52
                      Glad to hear you finally got it sorted.
                      You know of course that you are supposed to have separate .g files to home X, Y and Z.
                      • homeX.g
                      • homeY.g
                      • homeZ.g
                      You want to see my homeALL.g file?
                      M98 P"homeZ.g"
                      M98 P"homeX.g"
                      M98 P"homeY.g"
                      Yes it doesn't "optimize" homing as some folks do, such as homing X and Y at the same time but it does keep it simpler for my aging mind - the code to home a given axis exists in only one file.
                      • Pierre52undefined
                        Pierre52
                        @fcwilt Hi Frederick. Yes I did cut the relevant parts into X Y and Z homing files. Your input has also significantly reduced the number of lines in each. Thanks again for all your help.
                        Cheers
                        Peter
                        • fcwiltundefined
                          fcwilt @Pierre52
                          Cheers
                          Peter
                          Always glad to help when I can - and if I cannot help I will try to not make things worse. 😉
