    When Homing, Not traveling Correct Distance 3.3 beta1
    Beta Firmware
    827
    • Vetiundefined
      Veti @Toastinator
      @Toastinator said in When Homing, Not traveling Correct Distance:
      When will the duet start looking for Duet3_SDiap32_MB6HC.bin Files?
      for firmware update from 3.2
      • Toastinatorundefined
        Toastinator
        @Veti The Github should say Update to 3.2 First, Then to the Newest. The Small Details lol
          Toastinator
          @Veti
          After Further Testing, It still Does the Same thing, But Not Every Time. If you have any other ideas
            Toastinator
            Combined Movement on this CoreXY Duet 3 Expansion 1XD Boards Driving Nema 23 Closed Loop Stepper Motors Seem to be the Issue.
            This is Fine:
            G1 X100
            G1 Y100
            This Does not work:
            G1 X100 Y100
              In what way doesn't that command work- what does it do?
              Toastinatorundefined 1 Reply Last reply Reply Quote 0
                Toastinator @dc42
                Firmware 3.2.2: G1 X100 Y100 Moves about Half X and Y. While Printing, It Layer Shifts Continuously on the same Layer.
                But This Works Fine For some reason:
                G1 X100
                G1 Y100
                Firmware 3.3Beta1 The Machine Refuses to Home. It wont Recognize X or Y on the Expansion 1XD Boards. (Both 1XD Boards were also Upgraded to 3.3Beta1)
                  Toastinator
                  In the Image, The Printer is Continuously Layer Shifting Mid Layer In a Diagonal Fashion. These are Nema 23 Closed Loop Stepper Motors, Driven from 2 Duet 3 Expansion 1XD Boards for X and Y On a CoreXY Machine. Have to Use 3.2.2 Firmware Because 3.3Beta1 Will Not Home.
                    dc42 administrators @Toastinator
                    @Toastinator said in When Homing, Not traveling Correct Distance 3.3 beta1:
                    Layer shifts when using external drivers are a sign that the M569 T parameters are not right. Don't just guess, get the specifications for minimum step time, minimum step interval, minimum direction-to-step setup time, and minimum direction-to-step hold time needed by the drivers.
                    I'll reply regarding the homing issue in your other thread.
                    • Vetiundefined
                      Veti
                      T0:0:0:0
                      that sound wrong for timing
                      Toastinatorundefined 1 Reply Last reply Reply Quote 1
                        Toastinator @Veti
                        @Veti
                        I took it right from the Wiki Page.
                        "b This is setting T0:0:0:0 this allows the firmware to generate short pulses. in measurement these where no shorter than 0.7ns."
                        But I also Tried Removing it aswell, Leaving the Default.
                        "On the EXP1XD board the default is T2.6:2.6:2.6:2.6"
                        When I get home later tonight, Ill play around with Timing and see what happens.
                          jay_s_uk @Toastinator
                          @Toastinator you need to look at the datasheet for your drivers to determine the timing required. I suspect it will be higher than the 1XD defaults as well
                            Toastinator @jay_s_uk
                            @jay_s_uk
                            The Datasheet I was given does not Mention any Required Timing. It just says it accepts from 0-200Khz Pulse Frequency.
                            JSS57P2N Instruction manual
                            After Changing Timing to T5:5:5:5 and T10:10:10:10, It Seams to Move Fine, But there is Some Type Of error Accumulating. (Or somthing else, lol)
                            Yesterday, I was Getting Homing Errors. Today Without Changing Anything, Its Homing Fine, But Not waiting for the Hotend to Heatup before Moving. And Look at this Picture of a No Infill Cube. The Infill Filled in Slightly Wavy at the Bottom.
