    Firmware bundle 3.2.2 released
    Firmware installation
    13
    30
    3.1k
    • taconiteundefined
      taconite
      @resam that already happend to me from 3.1 to 3.2 on multiple occasions and I always needed to install the wifi server afterwards to bring wifi back to live
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • resamundefined
        resam
        @taconite indeed! Thanks! I'm not on RRF 3.2.2 with working Wifi.
        I don't remember having this issue in the past.
        @dc42 Thats a weird bug though because the WifiFirmware did not change at all - so why does RRF fail here after the upgrade? I power-cycled everything a few times. Is this a bug which corrupts data in the eeprom?
        • fcwiltundefined
          fcwilt @resam
          @resam said in Firmware bundle 3.2.2 released:
          I think this release just broke Wifi on my Duet2 Wifi...
          Well it's not an inherent problem with the 3.2.2.
          I just upgraded as usual from 3.1.1 and it all went fine.
          No problems re-connecting.
          Is your WiFi server up to date?
          • SIamundefined
            SIam
            Here the same problem after update from 3.2 to 3.2.2 Wifi is not working anymore i used the Duet2and3Firmware-3.2.2.zip file
            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
            Duet WiFi 1.02 or later + DueX5
            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
            Duet WiFi Server: 1.26
            Duet Web Control 3.4.0beta4 (2021-09-27)
            • MJLewundefined
              MJLew
              Worked for me on two printers with Duet 2 Wifi. One was update from 3.1.1 and the other from 3.2. Updated and restarted and both printers appeared on the net.
                For anyone having issues with WiFi after upgrading, I suggest you connect via USB and then send M997 S1 to reinstall the WiFi server.
                If you are already running release 3.2.0 then instead of uploading the full zip file you could install just the new firmware binary and DWC. The WiFi server and IAP files have not changed since release 3.2.
                • SIamundefined
                  SIam
                  thank you !now it's working
                  • Fodenundefined
                    Foden
                    Have a DuetWifi (v3.1.1)
                    Downloaded RepRapFirmware 3.2.2 upgrade and installed, as per notes, Duet2and3Firmware-3.2.2.zip through the System page of Duet Web Control. Once uploaded I was asked if I wanted to apply to upgrade and I said Yes. Web page cycled continuously looking like it was upgrading, left it for 2 mins. Checked the Duetpanel display and it said "ERROR: Operation 3 failed after 5 retries" . I clicked the X xlose gadget and the printer said 'Firmware uploaded in the top right corner of the screen. Checked the web interface and it was still cycling as though it was upgrading. Power cycled the printer and it's not very happy. Stuck saying 'Initializing' to right.
                    So I followed Fallback procedure #3 and uploaded 'Duet2CombinedFirmware.bin' via Basso, once the printer was reset it seemed to be OK. So I retried the upgrade via the web interface and got the same issue.
                    Not sure what I'm doing wrong
                      Phaedrux Moderator @Foden
                      @Foden I would try re-downloading the zip file again.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                      Can you post the results of M122?
                      • Fodenundefined
                        Foden
                        Hi Phaedrux
                        Hope you are safe & well. Have downloaded the file again, 3rd time, and about to retry the update again
                        Current M122 is
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                        Board ID: 08DDM-9FAM2-LW4S8-6J9FD-3S86R-9MYVX
                        Used output buffers: 3 of 24 (24 max)
                        Static ram: 23460
                        Dynamic ram: 73376 of which 76 recycled
                        Never used RAM 15168, free system stack 115 words
                        Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:43:42 ago, cause: power up
                        Last software reset at 2021-01-30 13:14, reason: User, GCodes spinning, available RAM 15168, slot 1
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU temperature: min 25.3, current 30.2, max 31.9
                        Supply voltage: min 24.4, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 18752, standstill, SG min/max 0/88
                        Driver 1: position -1152, standstill, SG min/max 0/60
                        Driver 2: position 2937, standstill, SG min/max 0/473
                        Driver 3: position 0, standstill, SG min/max not available
                        Driver 4: position 0, standstill, SG min/max not available
                        Driver 5: position 0
                        Driver 6: position 0
                        Driver 7: position 0
                        Driver 8: position 0
                        Driver 9: position 0
                        Driver 10: position 0
                        Driver 11: position 0
                        Date/time: 2021-02-16 14:01:23
                        Cache data hit count 3203037067
                        Slowest loop: 42.50ms; fastest: 0.21ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 40.4ms, write time 0.0ms, max retries 0
                        DMs created 83, maxWait 80640ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 10, completed moves 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 15.54ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is active
                          WiFi firmware version 1.25
                          WiFi MAC address ec:fa:bc:0b:ef:f2
                          WiFi Vcc 3.44, reset reason Power up
                          WiFi flash size 4194304, free heap 23760
                          WiFi IP address 192.168.1.52
                          WiFi signal strength -49dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                        • Fodenundefined
                          Foden
                          Same error - "ERROR: Operation 3 failed after 5 retries" - Web page shows "Please wait while updates are being installed..." 😞
                            @Foden what version of dwc is it showing installed?
                            Fodenundefined 1 Reply Last reply Reply Quote 0
                              "Operation 3" means the firmware flasher has initialised, unlocked, and erased the flash memory, but failed to write the new firmware. The failure could either happen when reading from SD card or when writing to flash memory. So it's worth trying a new SD card.
                              • Fodenundefined
                                Foden
                                K, will try a new card
                                • Fodenundefined
                                  Foden
                                  👎 Not sure what happened - tried a different card but am now NOT able to connect to the DuetWifi via USB and Bossa. Laptop shows the Duet as Com5, Bossa sees Com5 but says "Cannot connect to device on Com5"
                                  • Fodenundefined
                                    Foden @Phaedrux
                                    @Phaedrux It did say 3.2.2 but now I can't get to it via Bossa at all
                                    • Fodenundefined
                                      Foden
                                      @Foden I'm an idiot - in the process of detailing the above it dawned on me I had NOT pressed Erase 😧 Doing so allowed me to connect via Bossa to upload Duet2CombinedFirmware.bin
                                      (deleted the large post with photos as it was redundant and in the way - sorry)
                                      • Fodenundefined
                                        Foden @Foden
                                        @Foden Happy Days!!! Was able to apply the 3.2.2 upgrade and it applied OK. Wifi showed as connected but not able to connect to it just yet. Will reset and retry that shortly
                                        Fodenundefined 1 Reply Last reply Reply Quote 1
                                        • Fodenundefined
                                          Foden @Foden
                                          @Foden Hmm. Duetwifi reports it is connected to Wifi, as does my router, but I cannot connect to it via it's IP address
                                          Going to switch it all off and walk away for a bit as my brain was obviously in DFU mode earlier and may still be stuck there
                                          Appreciate your help guys - as always
                                            @Foden said in Firmware bundle 3.2.2 released:
                                            Double check the IP address. Clear the cache. Try a different browser. Verify that the /www folder contains the right files. If in doubt, replace the files in the /www folder with fresh ones from the DWC zip file.
