    Remote control the Duet 3
    834
      If your Duet is connected to your WiFi router, you should already be able to connect to it from your smartphone.
        jay_s_uk @Anthoval
        @Anthoval if you want to continue to run in standalone (i.e. no SBC) but want to utilise wifi, then an ethernet to wifi adapter is the way to go.
        • Anthovalundefined
          Anthoval
          Okay good to know. I've been thinking about something. Would it be possible to send ethernet frames to the Duet and expect it to react as if you used DWC? So basically, trigger macros on the Duet without using DWC.
          • Vetiundefined
            Veti @Anthoval
            @Anthoval said in Remote control the Duet 3:
            i assume you mean http requests?
            yes. you can see the requests being send in the debug console of your browers.
            these can be send via any other tool
            also the duet has a telnet interface
              Available http cpommands are documented at https://github.com/Duet3D/DuetWebControl/blob/legacy/README.md. There is an additional command rr_model that isn't included in that list.
              • Anthovalundefined
                Anthoval
                Great, thanks for your advices. My goal here is to remote control the Duet without using any browser, I'll reply here to give a feedback on how things went!
                  Phaedrux Moderator @Anthoval
                  @Anthoval Take a look at some of the options here: https://duet3d.dozuki.com/c/Community_Projects
                    I have added page https://duet3d.dozuki.com/Wiki/HTTP_API to replace the outdated one in Duet Web Control github.
                    chrishammundefined 1 Reply Last reply Reply Quote 1
                    • chrishammundefined
                      chrishamm administrators @dc42
                      I'll leave these links here as well:
                      RRF in standalone mode:
                      https://github.com/Duet3D/RepRapFirmware/blob/v3.02-dev/HTTP requests.md
                      https://github.com/Duet3D/RepRapFirmware/blob/v3.02-dev/JSON responses.md
                      RRF in SBC mode (DSF):
                      https://github.com/Duet3D/DuetSoftwareFramework#rest-api
                      Duet software engineer
                        @chrishamm, I had lost track of those! Still missing rr_model though.
