Duet2 with two heater cartridges
    rexx
    Hello all
    What is the best way for me to activate another 50w heater and tie it to the one thermistor
    undefined 1 Reply Last reply 18 Feb 2021, 21:43 Reply Quote 0
      fcwilt @rexx
      @rexx said in Duet2 with two heater cartridges:
      Hello all
      What is the physical arrangement? Is the new heater heating the same thing as the existing heater?
        rexx
        Yes I would add a second to the hot end for a total of 100w 50w each into one hot end
        undefined 1 Reply Last reply 18 Feb 2021, 22:07 Reply Quote 0
          fcwilt @rexx
          Something like this - I'm only showing the commands relevant to your question - your setup will likely be different.
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor
          M950 H0 C"out0" T0 Q250 ; create heater output and map it to sensor 0
          M950 H1 C"out1" T0 Q250 ; create heater output and map it to sensor 0
            rexx
            Ok I get that part thank you, but where would I get the power on duet 2 is the line out able to support 100w wired 50 each or how is best to make it complete to one tool/hotend/head...thermistor is another board needed
            undefined 1 Reply Last reply 18 Feb 2021, 23:23 Reply Quote 0
              fcwilt @rexx
              The duet has two extruder heater outputs E0 HEATER and E1 HEATER - each is good to 6 amps - a 50 watt heater on 24 volts should draw a bit more than 2 amps.
                As they are heating the same thing and the heaters draw only 2A each, it would be best to connect both heaters in parallel to a single heater output.
                1 out of 7
