    Problem with z-probe offset
    1.1k
    • koaldesignsundefined
      koaldesigns
      Currently the z-probe works and activates, it's just that the defined z offset in the G31 command isn't being used and instead defaults to .7mm. I have looked in the RRF source files and can't see as to why it is defaulting to the .7mm
      • fcwiltundefined
        fcwilt
        @koaldesigns said in Problem with z-probe offset:
        This is invalid - delete it - or comment it out: M574 Z1 S2 ; configure Z-probe endstop for low end on Z
        This serves no purpose - do that same as above: M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
        You have no X and Y offset values in this: G31 P500 Z2.41
        To be safe add them: G31 P500 Xnnn Ynnn Z2.41 where nnnn are the actual values for your printer.
        I have never encountered any situation where the Z offset value is simply ignored.
        Why do you think it is being ignored?
          koaldesigns
          @fcwilt I have modified my config.g to what you suggested:
          ;Endstops
          M574 X1 S1 P"!xstop"   ; X min active low endstop switch
          M574 Y1 S1 P"!ystop"   ; Y min active low endstop switch
          M574 Z1 S0             ; configure Z-probe endstop for low end on Z
          ;Z-Probe
          M558 P1 C"zprobe.in" H18 F200 R.5 T3600 # Z-Probe connected to Z-endstop input
          G31 P500 X1 Y1 Z2.41
          M557 X150:600 Y-450:450 S50 ; probe from X=10 to 190, Y=10 to 190mm with a mesh spacing of 20mm
          I have tested this and the offset is still .7mm even though it is defined as 2.41mm. I have changed the dive height (H) and after homing it is always the dive height (H) +0.7mm instead of H + 2.41mm so the trigger height is definitely being ignored.
          • fcwiltundefined
            fcwilt @koaldesigns
            @koaldesigns
            Odd.
            Please post your homeALL.g and homeZ.g files
              koaldesigns
              I do not have a home.z files as it is impossible for my printer to only home the Z-axis as it is dependent on the other axis being homed. My homeall.g is as follows:
              G91							;Relative positioning
              M561					;Remove any mesh leveling
              G92 W0					;Set Z to 0 (temporary no z stop yet)
              G1 H2 Z30 F400
              G0 H1 Y-300 X-300 F800		;Move both distal and proximal to home positions
              G0 H2 X5 F200				;Slowly turn proximal away from home position
              G0 H1 X-10 F200				;Slowly home proximal
              G0 H2 Y5 F200				;Slowly turn distal away from home position
              G0 H1 Y-10 F200				;Slowly home distal
              G90							;Absolute positioning
              G0 H2 X-60 Y60 W0 F800			;Move arm to center of range
              G30
              @fcwilt
              • fcwiltundefined
                fcwilt @koaldesigns
                @koaldesigns
                I don't think you need the H2 parameters on the X and Y moves.
                Everything else looks fine.
                When you say it ends up at dive height + 0.7mm - is that as reported by the DWC or are you measuring it?
                  koaldesigns
                  I do need the H2 parameters because it's a SCARA machine. Everything has been tuned and works properly for what I need except the z offset. Also, I don't have to measure it because that's what the firmware says, and when I move to Z0, the hotend is always the same distance above the bed no matter the z-offset so it is being ignored. @fcwilt
                  • fcwiltundefined
                    fcwilt @koaldesigns
                    @koaldesigns
                    Have you executed a G31 from the console after booting to see what it reports?
                    You don't by chance have another G31 somewhere this overriding the one in config.g?
                      koaldesigns
                      The G31 command yielded this before and after homing:
                      G31
                      Z probe 0: current reading 487, threshold 500, trigger height 2.410, offsets X1.0 Y1.0
                      but still reports 18.7mm z height after homing when it should be 20.41. @fcwilt
                      • fcwiltundefined
                        fcwilt @koaldesigns
                        G31
                        What kind of probe is it?
                        That reading of 487 is awfully close to the threshold value.
                        I noticed that in your homeALL.g file you used G92 W0 with the comment that there was no Z end stop yet.
                        It got me to thinking. Does your printer have a axis named Z? If not how does G30 know to move on W.
                        Curious.
                        The only other thing I can think of is that 3.2 has a bug. I know for my printer with 3 Z steppers each with their own Z end stop switch there was a bug that prevented it from working correctly.
                          koaldesigns
                          The W axis is a wrist joint and is irrelevant for this. I'm going to give it a break for tonight and see whats up tomorrow. It could be something to due with mesh bed leveling but I'm unsure. @fcwilt
                            Do you get any errors when sending M98 P"config.g"?
                            • chas2706undefined
                              chas2706
                              Sorry to hijack this thread but would just like to get something off my chest.
                              Ive had problems with both my corexy printers regarding Z height and first layer issues since upgrading from RRF3.1.1. Both printers have SBC. They both now running on RRF3.2.2 and neither are capable of printing anything from scratch without my intervention. Each time I have to adjust babystepping to get the first layer height correct.
                              Example: In config.g one printer has Z offset G31 X-30 Y-5 Z2.72 which was found by doing correct process to find Z height. On attempting to print, Z is too high. If I lower Z by 0.28 using on the fly babystepping the first layer is spot on. Before next print I change G31 in config.g to G31 X-30 Y-5 Z3.0 so as to equal the difference with babystep. On next print Z is too low and babystepping back up by 0.28 corrects this!!!!
                              Just in case I'm doing something wrong I then change config to G31 X-30 Y-5 Z2.44 (minus 0.28). This time the print too low by 0.28!!!
                              Both printers have similar issue and neither printer has any other G31 command in any other piece of gcode or macro.
                              I have only one functional printer which is old faithful ender 3 pro which in my opinion prints every time because there's no Z probe present, everything is set up manually, no SBC attached and therefore much simpler.
                              Ever since RRF3 firmware versions have been available I've had issues and still have issues with SBC not always connecting to DCS, when booted up, sometimes config.g not been processed so DWC shows no extruders, no heaters, no fans etc...
                              It was months and months ago that i first reported an issue that any gcode command that I enter into the console in DWC has to be clicked on twice before DWC responds, I find that this issue is STILL present and has now even expanded to include the emergency stop icon on DWC. So at one point my head crashed into the bed because the emergency stop does not always work first time!!!
                              Lastly, I fail to understand how on both printers with SBC attached i often encounter "network failed, no network connection" showing on SBC's DWC but im somehow happily connected to DWC via laptop!!
                              I spent £1500 on my last printer but the best and most reliable prints come from my simple £250 Ender 3.
                              Rant over, feel better now!
                                Phaedrux Moderator @chas2706
                                @chas2706 said in Problem with z-probe offset:
                                Well that's something at least. 😉 Feel free to start a new thread if you want to work through any other issues.
                                • chas2706undefined
                                  chas2706
                                  R
                                  Phil Maddoxundefined 2 Replies Last reply Reply Quote 1
                                  • Phil Maddoxundefined
                                    Phil Maddox @chas2706
                                    @chas2706 Im experiencing pretty much the same behavior . I need 0.280 in baby stepping to even get the print on the bed
                                      @chas2706 Updated to 3.2.2 and removed a space i had before the Z numerical field in config.g and my problems have gone away
                                      Good luck
