    Emergency Stop does not reset
    • chimaeraghundefined
      chimaeragh
      Hi. I am having an issue where pressing a hardware emergency stop button and releasing it does not reset the board unless I click reset controller popup in DWC.
      Duet2Wifi on RRF3.2.2
      Here are the contents of my customconfig.g
      ; ADD ANY CUSTOM SETTINGS BELOW
      M950 J1 C"e1stop" ; Assign Pin1 to e1stop
      M581 P1 T0 S1 R0  ; Enable Emergency Stop Normally Closed
      M582 T0
      Duet 2 Wifi, Ooznest Workbee CNC 1510
      • fcwiltundefined
        fcwilt @chimaeragh
        @chimaeragh
        Yes - that's the way it works.
        What would you like it to do?
        chimaeraghundefined 1 Reply Last reply Reply Quote 0
          chimaeragh @fcwilt
          @fcwilt said in Emergency Stop does not reset:
          @chimaeragh
          I would prefer that releasing the emergency stop button would reset the controller without having to click anything on the screen.
          • fcwiltundefined
            fcwilt @chimaeragh
            @chimaeragh said in Emergency Stop does not reset:
            I'll hazard a guess that they do it the way it is now so you can stop whatever is going on and examine the state of the machine.
            An automatic reset would make that impossible.
