    Cannot get BL Touch to work!
    Third-party add-ons
    481
    • nedmoundefined
      nedmo
      I have followed the guides on both Betrue and Duet and cannot get my BL Touch V3 to react to any commands.
      My setup is as follows.
      Black/white to z probe in and GND
      Yellow to pin 8 (heater 3)
      Red to pin 1
      Brown to pin 2
      On machine startup, it executes the self test successfully, then red LED lights up and stays on.
      I have tried sending all of the m280 commands to test, deploy and restract and nothing happens.
      Here is my Config.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 19 2021 15:39:15 GMT+1100 (Australian Eastern Daylight Time)
      M550 P"V-King CXY" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 Z16 E16:16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z3200.00 E406.00:406.00 ; set steps per mm
      M566 X900.00 Y900.00 Z150.00 E600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z600.00 E21600.00:21600.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z120.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z600 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X320 Y370 Z330 S0 ; set axis maxima
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T18000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X48 Y10.8 Z1.2 ; set Z probe trigger value, offset and trigger height
      M557 X0:320 Y15:370 S100 ; define mesh grid
      M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M308 S2 P"e1temp" Y"pt1000" R4700 ; configure sensor 2 as PT1000 on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S300 ; set temperature limit for heater 2 to 300C
      M106 P1 S1 H1:2 T50 ; set fan 1 value. Thermostatic control is turned on
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X20 Y0 Z0 ; set tool 1 axis offsets
      T0 ; select first tool
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 29 2020 09:03:19 GMT+1000 (Australian Eastern Standard Time)
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 29 2020 09:03:20 GMT+1000 (Australian Eastern Standard Time)
      M280 P0 S90 ; retract BLTouch
      Any help would be appreciated.
      Thanks
      Ned
      • nedmoundefined
        nedmo
        Ignore that my Retract and Deploy versions dont match...they are all for 3.2.3 now.
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          @nedmo said in Cannot get BL Touch to work!:
          Can you change the setup to exp.heater7?
          Try that in the first step.
          Wiring up the BL-Touch to exp.heater3 does make some trouble. I can't get why, but we had that several times here.....
          (UTC+1)
          nedmoundefined 1 Reply Last reply Reply Quote 0
          • nedmoundefined
            nedmo @DIY-O-Sphere
            @DIY-O-Sphere
            I have moved the Yellow wire to pin 31
            and attempted to redo the config.
            M307 H7 A-1 C-1 D-1 ; disable heater 7
            M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
            M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
            But, when I send M307 H7 I am getting this.
            m307 h7
            Heater 7 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
            Computed PID parameters for setpoint change: P13.4, I0.482, D51.4
            Computed PID parameters for load change: P13.4
            • nedmoundefined
              nedmo
              Ok, i got heater 7 disabled now.
              Still nothing happens if I send a M401 or M402. The notification is green though indicating that the command was sent successfully.
              • Vetiundefined
                Veti
                what firmware version are you on?
                • nedmoundefined
                  nedmo @Veti
                  @Veti
                  3.2 I think. I can check in the morning.
                    Phaedrux Moderator @nedmo
                    Not used in RRF3.
                    Verify your firmware version with M115. Your config looks OK for RRF3, but obviously won't work if your installed firmware is actually 2.x
                    • Vetiundefined
                      Veti @nedmo
                      your config is not consistent your entire heater and thermistor config is rrf2
                      • nedmoundefined
                        nedmo
                        Hi all,
                        Ok yep, I thought I had upgraded to 3.0, but I was still on 2.5
                        Now upgraded to 3.2.2. Just ran a fresh config of the RRF3.2.3
                        And now i am getting my previous issues with H1 and H2 faulting and showing 2000c. Bed is working correctly.
                        But, good news is that i just ran a M401 and M402 and BLtouch deployed and retracted. So, now I will follow the betrue guide to try a homing operation
                        Here is my current config.
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Feb 24 2021 12:07:14 GMT+1100 (Australian Eastern Daylight Time)
                        M208 X330 Y390 Z330 S0 ; set axis maxima
                        G31 P500 X48 Y-10.8 Z1.2 ; set Z probe trigger value, offset and trigger height
                        M557 X0:290 Y15:370 S100 ; define mesh grid
                        • nedmoundefined
                          nedmo
                          I am using Semitec 104 GT thermister. I was told I need this config
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
                          All problems are now solved and now onto getting the mesh level
                          fcwiltundefined 1 Reply Last reply Reply Quote 2
                          • fcwiltundefined
                            fcwilt @nedmo
                            @nedmo
                            Glad to hear you got it sorted.
