    Problem with tool definition and extruder control
    Duet Web Control
    695
    • Kirolefuundefined
      Kirolefu
      Hello forum,
      I have a problem with the setting of the extruder on my Duet 2 Wifi. The board is used in my CoreXY self-made. I have everything running correctly except for the extruder. When I first wanted to calibrate the extruder, the Z-axis went down. The whole thing comes from the fact that I have a double Z drive and the second motor is controlled via the E0 output. Both motors have separate optical end stops. I thought the problem could be solved easily by setting E0 to E1 instead of motor control for M563 in config.g. However, after the change in the dashboard, the tool is no longer displayed and I can no longer extrude. The tool is back on E0, but I can no longer use the extruder control. It doesn't matter what I do no longer selectable. I hope someone knows how to get the problem under control. I've been sitting here on the bug for a week and don't know what to do next.
      Board: Duet 2 Wifi
      Duet Web Control 3.1.1
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.9 on Tue Dec 01 2020 19:02:26 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Kiro1" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1
      M584 Z2:3 ; set drive mapping
      M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 U400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 U12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z600.00 U600.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z250.00 U250.00 E800.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 U1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1 ; set axis minima
      M208 X300 Y200 Z200 U200 S0 ; set axis maxima
      M574 X1 S1 P"XStop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"YStop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 P"ZStop+e0stop" ; configure active-high endstop for low end on Z via pin Zstop
      M558 P5 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to switch and the dive height + speeds
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT1000 on pin e0temp
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M911 S23 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        jay_s_uk
        @Kirolefu said in Problem with tool definition and extruder control:
        change this line to
        M584 X0 Y1 Z2:3 E4
        Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
        • Kirolefuundefined
          Kirolefu
          I changed M584 but nothing happens. Extrusion Control cannot be selected. not even after M302 P1cold extrude
          • Rushmere3Dundefined
            Rushmere3D @jay_s_uk
            This post is deleted!
              jay_s_uk @Kirolefu
              @Kirolefu I can't see anything else wrong with your config.
              I've compared it against my one.
              Did you reboot when you made the change?
              • Kirolefuundefined
                Kirolefu
                Yes after changing I reboot the System. When I changed M563 M563 P0 D0 H1 F0 to M563 P0 D1 H1 F0, the tool is no longer visible in the dashboard.
                  jay_s_uk @Kirolefu
                  @Kirolefu don't change that line as D0 is still valid
                  • Kirolefuundefined
                    Kirolefu
                    I changed it again but I can't select anything in the extrusion control. 😞
                      jay_s_uk
                      can you try heating up the hotend?
                      • Kirolefuundefined
                        Kirolefu
                        Yes Pid tuning and heating up works
                          deckingman @Kirolefu
                          @Kirolefu You need to select a tool before you can extrude with it. Try sending T0 first, or better still, add T0 to the end of your configuration file (that's Tzero). Let us know if that helps...........
                          • Kirolefuundefined
                            Kirolefu
                            Yes it works 🙂 I didn't know that you had to select the tool before. Thank you for the quick help. You saved my day.
                              Glad it worked.
