    Duet Wifi - how to set cooling fan?
    Firmware installation
    961
    • eranglrundefined
      eranglr
      I've upgraded the firmware (3.0)
      The cooling fan is connected to FAN0, but no matter what I do, the fan is always working (tested FAN1 and FAN2 - same thing).
      How should I set it so I can use M106 command to make it work?
        jay_s_uk
        post your config please
        • eranglrundefined
          eranglr
          config.txt
          While I'm here, cold extrusion stopped working.
            jay_s_uk
            your config has a mixture of RRF2 and RRF3 commands.
            I suggest creating a new config using the config tool https://configtool.reprapfirmware.org/
            and then transferring across any changes you've made
            • eranglrundefined
              eranglr
              Here is the new config:
              Config-RRF.txt
                jay_s_uk
                that looks correct although you shouldn't be including M587 commands in your config
                eranglrundefined 1 Reply Last reply Reply Quote 0
                • eranglrundefined
                  eranglr @jay_s_uk
                  @jay_s_uk My cooling fan is connected to FAN0, but when sending M106 S0 it doesn't do anything (it's always on).
                    jay_s_uk
                    is it always on when the sd card is not inserted into the board and then the board is powered on?
                      droftarts administrators @eranglr
                      @eranglr You have it mapped to the tool T0 with M563 P0 D0 H1 F0. So it won't be active until the tool is active. Actually, that's not it at all!
                      Check that you have connected the fan to FAN0, and not the 'Always on' pins. See the wiring diagram: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                      eranglrundefined 2 Replies Last reply Reply Quote 0
                      • eranglrundefined
                        eranglr @droftarts
                        @droftarts connected it to FAN0 (not always on).
                        The fan is always on even when I turn the duet with no SD card inside.
                        • eranglrundefined
                          eranglr @droftarts
                          This post is deleted!
                            @eranglr Can you send M122 and post the reply?
                            • eranglrundefined
                              eranglr @jay_s_uk
                              @jay_s_uk yes, it is.
                              Could it be a jumper or something like that?
                              • eranglrundefined
                                eranglr @droftarts
                                @droftarts
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                                Board ID: 08DJM-9178L-L4MSJ-6J1FL-3SN6T-TV16Q
                                Used output buffers: 3 of 24 (11 max)
                                Static ram: 23460
                                Dynamic ram: 73136 of which 40 recycled
                                Never used RAM 15444, free system stack 182 words
                                Tasks: NETWORK(ready,188) HEAT(blocked,308) MAIN(running,379) IDLE(ready,20)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:00:43 ago, cause: power up
                                Last software reset at 2021-02-24 17:24, reason: User, GCodes spinning, available RAM 15444, slot 1
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 35.1, current 38.2, max 38.5
                                Supply voltage: min 26.8, current 26.9, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 0, standstill, SG min/max not available
                                Driver 1: position 0, standstill, SG min/max not available
                                Driver 2: position 0, standstill, SG min/max not available
                                Driver 3: position 0, standstill, SG min/max not available
                                Driver 4: position 0, standstill, SG min/max not available
                                Driver 5: position 0
                                Driver 6: position 0
                                Driver 7: position 0
                                Driver 8: position 0
                                Driver 9: position 0
                                Driver 10: position 0
                                Driver 11: position 0
                                Date/time: 2021-02-24 17:40:35
                                Cache data hit count 51187488
                                Slowest loop: 4.02ms; fastest: 0.21ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 16.13ms; fastest: 0.00ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.23
                                  WiFi MAC address bc:dd:c2:31:9f:e7
                                  WiFi Vcc 3.37, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 24208
                                  WiFi IP address 192.168.202.42
                                  WiFi signal strength -64dBm, mode none, reconnections 0, sleep mode modem
                                  Clock register ffffffff
                                  jay_s_uk @eranglr
                                  @eranglr my guess is you've blown the fan mosfet.
                                  Can you take a high quality close up photo of the area around the connector, specifically the area between the fan connectors and the two LCD headers
                                  • eranglrundefined
                                    eranglr @jay_s_uk
                                    @jay_s_uk This is a brand new card, so I doubt if I blow the MOSFET.
                                      jay_s_uk
                                      ok then, i'll let someone else step in and support
                                      • eranglrundefined
                                        eranglr @jay_s_uk
                                        @jay_s_uk Just for fun, where's the mosfet, and are there 3 mosfet (one for each fan)?
                                          @eranglr And it would be very unlucky if it's blown all the mosfets, as he said it was the same for FAN1 and FAN2.
                                          Is there any chance the fan you are using is shorting out to ground somewhere else? Is it wired directly to the fan pin, or does it go through something else?
                                          The MOSFETs work on the negative side of the fan, so the fan gets +ve volts all the time, so if there is a short on the negative side, it will always be on.
                                          If you can post a photo of your wiring, that may help.
                                            jay_s_uk
