Duet Maestro Z-Home moves X&Y axis.
the G1 X Y moves the X and Y to the defined point where you probe.
so x and y movement is expected.
if the z axis does not move then that is where the problem is.
first update to 2.05.1 first.
then check the wiring of the z stepper motor.
Agreed XY moved is expected.
Removed the XY movement now I only need to get Z movement.Don't see how updating would fix this.
@JohnnyBeeGood You've got very high jerk and max speed set for Z. Could be the Z can't move, and you get a short to ground message when it tries. Try M566 Z12 and M203 Z600.
@JohnnyBeeGood said in Duet Maestro Z-Home moves X&Y axis.:
at first you posted there is no z movement.
for the firmware update. there were some fixed with the reporting in certain circumstances
The high jerk has not been a problem in the past (last week on the printer next to it), will try tomorrow.
Still not getting any Z-movement.
Il do the update tomorrow, to see if there is a change in reporting.
If this does not work Il pull the maestro from the printer that is now decommissioned, need to start printing enclosures.
what voltage are you running at?
if its 12v then that will be your problem because you are using the second z connector.
24v, have a separate supply 12V for fans and a peltier element.
Updated the firmware, no change in the error message.
Reduced the M566 and M203 settings, no change. -
try seperating the z motors anyway.
connect the second z motor to e1
see
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motorsyou gain bed leveling as well.
Had extension cables on the Z motors, took those out (taking these cables to there limit...) and now it works.
After the 2.05.1 update my XY movement is weird(xy-homing only moves 1 motor) but ill figure it out, thanks for you guy's attention! -
post your homing script.
if you created them without selecting corexy first. they may contain h2 movements for x and y which cause that.
TBH I don't know what it was, changed the motor orientations a couple of times and eventually came back to what I had and it worked. Now it's printing happily on the maximum speed I can extrude ~130mm/s, 300mm/s looked really cool until the extruder couldn't keep up...
what hotend are you using?
Mahor.xyz V3 pellet extruder.
