    RepRapFirmware 3.3beta1 now available
    Beta Firmware
    12
    36
    2.7k
    • User3Dundefined
      User3D @dc42
      @dc42 is it any different from 3.3beta release available on dropbox? (released 10-15 days ago)
        dc42 administrators @User3D
        @User3D said in RepRapFirmware 3.3beta1 now available:
        Yes, it's more recent. There is an even more recent one at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0 but it should only be used if you need the new features in it, described at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3_Beta.md.
        • oliofundefined
          oliof
          The deprecation of G10 for setting tool temperature is a bit awkward as PrusaSlicer only recently implemented support for using G10 for RepRapFirmware temperature control ...
          • chrishammundefined
            chrishamm administrators @oliof
            @oliof We'll undo the deprecation notice in the next beta, please ignore it for now.
            Duet software engineer
            • stewwyundefined
              stewwy
              Having a slight problem when I change from 3.2 to 3.3 beta 1 my z-probe does not work
              from my config.g file
              M558 P8 C"^!zprobe.in" H3 F500 T9000 ; set Z probe type to unfiltered(8) and the dive height + speeds (inductive probe via optocoupler)
              G31 P500 X-32 Y-26 Z3.020 ; set Z probe trigger value, offset and trigger height
              M557 X5:235 Y25:235 S15 ; define mesh grid
              Is my config a problem I checked the notes and could not see any indication of change
              The probe is a highly accurate industrial probe,
                dc42 administrators @stewwy
                @stewwy said in RepRapFirmware 3.3beta1 now available:
                Which Duet?
                • stewwyundefined
                  stewwy
                  Duet wifi 1.03
                  Should also note that it was constantly triggered (.i.e. the triggered light was on constantly)
                    Duet wifi 1.03
                    If it's connected via an optocoupler as you said, then there is no way that the Duet can cause the LED on the probe to light up.
                    • stewwyundefined
                      stewwy
                      My Bad I should have been clearer, Just finished a print on 3.2 now flashed 3.3 to check
                      The web page shows it as being on constantly ( Z-probe showing 1000 constantly) regardless of whether the z probe is triggered or not.
                      The probe indicator works normally, it turns on 8mm from the bed surface but is not being read properly by the duet. it works on 3.2 but not on 3.3.
                      • stewwyundefined
                        stewwy
                        OK that's interesting,
                        on 3.3 on first turning on the probe shows 0 on the web page
                        if I activate the probe ( with a piece of metal) the webpage z-probe display latches to 1000 to get it to zero again I have to restart the duet.
                        The optocoupler display led acts normally, on when probe activated, off when probe is not activated.
                          Post a schematic showing how the optocoupler is connected.
                          If the optocoupler is leaky then you might need to add an external pullup resistor between IN and +3.3V on the Z Probe connector.
