    Need help to fix this
    1.6k
    • tapeundefined
      tape
      only that wifi module connected
      no errors
      • Jackalundefined
        Jackal
        Can you provide a gcode file up to part of the first layer? and also your config.g
        • tapeundefined
          tape
          ok just tested with a gcode with no retraction and it works fine.
          how can i fix the retraction?
            Yes, please share the gcode file.
            • tapeundefined
              tape
              https://drive.google.com/file/d/0Bx0mLwkx-u8vdDctbEdvRUhvRTQ/view?usp=sharing
              • Jackalundefined
                Jackal
                What are your extruder speed and acceleration settings in your config.g?
                • tapeundefined
                  tape
                  M906 X800 Y800 Z800 E1000 ; Set motor currents (mA)
                  M201 X800 Y800 Z15 E400 ; Accelerations (mm/s^2)
                  M203 X15000 Y15000 Z240 E100 ; Maximum speeds (mm/min)
                  M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute
                  M208 X200 Y175 Z180 ; set axis maxima (adjust to suit your machine)
                  M208 X0 Y0 Z-0.2 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
                  M92 X80 Y80 Z4000 ; Set axis steps/mm
                  M92 E100:100
                    The problem is that you have set your maximum extruder speed to 100mm/min in the M203 command. That is very low and it is making retractions very slow. A more typical value would be 3000 to 6000 mm/min.
                    • tapeundefined
                      tape
                      thanks
                      • tapeundefined
                        tape
                        problem solved. thanks again
                        • FrankNPrinterundefined
                          FrankNPrinter
                          I had mine set at 1300 and was getting under extrudes at speed. Didn't even know i had this issues till i checked. Thanks dc42, you got a 2 for 1 on this solution 🙂
                          • number40fanundefined
                            number40fan
                            3 for 1. 1200 here. Getting bumped up.
                            Edit: Huge difference. I have been fighting layer issues and this was the fix. Looked up what the stock printer board was set to (9000) and changed it to that.
