Ender 5 Plus Duet 3 6hc
@Kanzleralexander a duet 3 6HC is probably overkill for an ender 5.
Have you looked at the Duet 3 mini 5+? https://www.duet3d.com/Duet3Mini5plus
It has 5 onboard drivers, can be expanded to 7 with an additional board and also has the capability to the CAN boards. -
@jay_s_uk Duet 2 WiFi?
@Kanzleralexander the duet 2 wifi is also viable, but the 3 mini5+ has the option for CAN, easier SBC support if you want to go that route, uses 2209 drivers with stall detection etc and is cheaper
@jay_s_uk Duet 3 6hc with 5160 Drivers.
@Kanzleralexander yea, the duet 3 has 5160 drivers but they are overkill for a standard 3d printer. Do you need to driver motors over 2amp?
@jay_s_uk what about FLY?
@Kanzleralexander currently the LPC/STM port doesn't support 5160 drivers but 3.3 beta 1 is being released this afternoon and that does have 5160 support
the FLY RRF E3 is a drop in replacement for the ender board.
though the mini 5 would be my go to.
@Veti Configuration?
ender 5 is not much different than the ender 3
see
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87 -
@jay_s_uk Configuration?
@Veti no, double Z and BLTOUCH
bltouch is mentioned in the guide
dual z is here
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
