Ender 5 plus - I need help
Using Duet Controllers
419
    Kanzleralexander
    Configuration file for Duet 3 (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 03 2021 22:50:58 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"Duet 3" ; set printer name
    M569 P0.0 S0 ; physical drive 0.0 goes backwards
    M569 P0.1 S0 ; physical drive 0.1 goes backwards
    M569 P0.2 S0 ; physical drive 0.2 goes backwards
    M569 P0.3 S0 ; physical drive 0.3 goes backwards
    M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
    M350 X32 Y32 Z32 E128 I0 ; configure microstepping without interpolation
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M201 X3000.00 Y3000.00 Z60.00 E250.00 ; set accelerations (mm/s^2)
    M84 S30 ; Set idle timeout
    M208 X350 Y350 Z400 S0 ; set axis maxima
    M574 X2 S1 P"!io0.in" ; configure active-high endstop for high end on X via pin !io0.in
    M574 Y2 S1 P"!io1.in" ; configure active-high endstop for high end on Y via pin !io1.in
    M574 Z2 S2 ; configure Z-probe endstop for high end on Z
    M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
    M558 P9 C"^io3.in" H5 F1800 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-44 Y-9 Z2.09 ; set Z probe trigger value, offset and trigger height
    M557 X10:350 Y10:350 S20 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T988801 B4185 C2200 ; configure sensor 0 as thermistor on pin temp0
    M143 H0 S110 ; set temperature limit for heater 0 to 110C
    M308 S1 P"temp1" Y"thermistor" T98801 B4185 C2200 ; configure sensor 1 as thermistor on pin temp1
    M143 H1 S260 ; set temperature limit for heater 1 to 260C
    M950 F0 C"out6" Q20 ; create fan 0 on pin out6 and set its frequency
    M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
    M950 F1 C"out7" Q20 ; create fan 1 on pin out7 and set its frequency
    M950 F2 C"out8" Q20 ; create fan 2 on pin out8 and set its frequency
    M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
    M563 P0 H1 F0 ; define tool 0
    M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    T0 ; select first tool
    strikethrough text
    undefined 2 Replies Last reply 3 Mar 2021, 23:18 Reply Quote 0
      Kanzleralexander @Kanzleralexander
      This post is deleted!
        @Kanzleralexander Fans and BLTOUCH -Do not work
        Is configuration correct?
          Can you provide the results of M122 and M98 P"config.g"? That would give us a good starting place.
          There are some guides for using a duet with the Ender 3 that may be helpful to you. The Ender 3 and 5 are quite close.
          https://duet3d.dozuki.com/Search?query=ender+3
          @Kanzleralexander said in Ender 5 plus - I need help:
          The part cooling fan probably doesn't work because it's set to be thermostatically controlled to turn on at 45c.
          Change this M106 P0 S1 H0 T45 to M106 P0 S1 H-1
          what exactly doesn't work with the bltouch?
          undefined undefined 2 Replies Last reply 4 Mar 2021, 00:31 Reply Quote 0
            Kanzleralexander @Phaedrux
            @Phaedrux my code:
            Endstops
            And i find in Internet for Ender 5 :
            Endstops
            M574 Z0 ; disabled end stop for z
            M574 X2 Y2 S1 ; set active high endstops
            ; Filament Sensor
            M591 D0 P1 S1 C3
            M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
            M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M557 X60:300 Y30:300 S30
            undefined 1 Reply Last reply 4 Mar 2021, 01:15 Reply Quote 0
              Kanzleralexander
              M106 P0 C"part-cooling" S0.65 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 C"hotend" S0.65 I0 F500 H1 T100 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S0.85 I0 F500 H-1
                Phaedrux Moderator @Kanzleralexander
                Endstops
                ; Filament Sensor
                M591 D0 P1 S1 C3
                That's for firmware 2.x your current config is for the more recent version 3 firmware.
                T100 mena sit won't turn the hot end heat sink fan until it's 100c which is hot enough to cause jamming. T45 is a better choice.
                  Phaedrux Moderator @Phaedrux
                  @Phaedrux said in Ender 5 plus - I need help:
                  Please provide this so we can see what firmware you're actually using.
                    Kanzleralexander
                    sys\config.g
                      Kanzleralexander
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Mar 04 2021 02:49:06 GMT+0100 (Mitteleuropäische Normalzeit)
                      M550 P"My Printer" ; set printer name
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M566 X900.00 Y900.00 Z60.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
                      M201 X3000.00 Y3000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                      M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
                      M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
                      G31 P500 X-44 Y-9 Z29 ; set Z probe trigger value, offset and trigger height
                      M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
                        Send M122 and M98 P"config.g" in the gcode console tab and post the results.
                        Also please describe what isn't working.
                        • Vetiundefined
                          Veti
                          the steps you configured are for x16 microstepping
                          4 out of 12
