Duet 3, SBC can I also run Octopi on the SBC for older printers
Using Duet Controllers
    warpster
    As the tittle says, I currently run a Railcore with a Duet 3 and toolboard. I'm thinking of adding the SBC to the Duet 3 and I was thinking it would be nice to also run Octopi on the SBC to manage a non Duet printer I have. Is this possible or is the SBC locked into the Duet role only?
      jay_s_uk
      that should be possible
        warpster
        Thanks for the reply. That's encouraging but me being an idiot as far as Linux goes does anyone have a link or some info to help accomplish this?
          gaweyo
          if you plan on running DSF and Octoprint on the same SBC you'll likely need some custom configs as both cannot use port 80 for their own webserver - but can be done.
            oliof
            Octoprint is already using a reverse proxy for the web serving, so binding DWC to a local IP and reverse proxying that should be possible.
            4 out of 5
