    Gantry leveling offset
    731
    • fcwiltundefined
      fcwilt
      Don't see anything wrong in those two files.
      Please post your homeALL.g file.
      maroondsundefined 1 Reply Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D
        This post is deleted!
        • maroondsundefined
          maroonds @fcwilt
          @fcwilt I usually have the g32 command in my start gcode. Here's the homeall.g file:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 22 2020 01:05:56 GMT+0200 (Mitteleuropäische Sommerzeit)
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-245 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-245 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
          G90                     ; absolute positioning
          G1 X0 Y0 F6000         ; go to first bed probe point and home Z
          G30                     ; home Z by probing the bed
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          • Vetiundefined
            Veti
            post the output of 3 consecutive G32
            also after a G32, you need to home z again.
            • fcwiltundefined
              fcwilt @maroonds
              @maroonds
              The only thing I would change is the XY position when using G30.
              I always use the same exact XY position whenever I do a G30 and I always use the center of the bed.
              And as mentioned you need to do a G30 after doing one or more G32s.
              Since it may take more than one G32 to get things level I do it this way:
              ; *** bed.g ***
              ; --- set positions of ball studs for auto-leveling (S is max allowed adjustment)
              M671 X-180:0:180 Y-65:130:-65 S3
              ; --- run first pass ---
              M98 P"bed_3.g"
              ; --- if deviation is too large run additional passes ---
              while move.calibration.initial.deviation >= 0.02
                ; check if pass limit reached
                if iterations = 5
                  abort "Bed Leveling Aborted - Pass Limit Reached"
                ; run next pass
                M98 P"bed_3.g"
              ; *** bed_3.g - called by bed.g ***
              ; --- probe near ball studs ---
              G30 P0 X-145 Y-65 Z-99999    ; probe near ball stud #1
              G30 P1 X0    Y100 Z-99999    ; probe near ball stud #2
              G30 P2 X145  Y-65 Z-99999 S3 ; probe near ball stud #3
              ; --- set Z=0 datum ---
              M98 P"center_probe.g"        ; position to center of bed for probing
              G30                          ; do single probe which sets Z to trigger height of Z probe
              • maroondsundefined
                maroonds @Veti
                @Veti
                7.3.2021, 13:20:13 g32
                Leadscrew adjustments made: -0.035 0.005, points used 2, deviation before 0.016 after 0.000
                7.3.2021, 13:19:38 g32
                Leadscrew adjustments made: -0.028 0.006, points used 2, deviation before 0.012 after 0.000
                7.3.2021, 13:19:05 g32
                Leadscrew adjustments made: -0.041 0.043, points used 2, deviation before 0.021 after 0.000
                • fcwiltundefined
                  fcwilt @maroonds
                  @maroonds said in Gantry leveling offset:
                  @Veti
                  For reasons lost in the mists of time as you can see if my bed_3.g file I include a single G30 after the leveling pass.
                  I know you need to do a G30 but I don't know if you need to do it after each pass or after all passes.
                  maroondsundefined 1 Reply Last reply Reply Quote 1
                  • maroondsundefined
                    maroonds @fcwilt
                    @fcwilt Could my issues come from my rather old firmware version?
                    If so, is there a config converter from RRF2 to RRF3?
                    • fcwiltundefined
                      fcwilt @maroonds
                      It's possible but it has been quite a while since I used v2 so I don't have any specific recollection.
                      I don't know of a convertor. I converted by editing my existing files. It wasn't as much work as I thought it would be.
                      I've never used the RRF configuration tool so I don't know if you can load a v2 .json file into the v3 tool.
                      Stephen6309undefined 1 Reply Last reply Reply Quote 0
                      • Stephen6309undefined
                        Stephen6309 @fcwilt
                        @fcwilt I'veloaded a v2 json for a v3 config. It won't populate any of the pin stuff.
                        • fcwiltundefined
                          fcwilt @Stephen6309
                          @Stephen6309 said in Gantry leveling offset:
                          Not too surprising since v2 didn't use pin assignments.
                          Thanks for the feedback.
