    Additional outputs using a SX1509B Expander
    Accessories and Add-ons
    1.3k
    • t0biasundefined
      t0bias
      I may be wrong, but I think pull-up resistors can only be enabled on ports of the Duet board itself.
      There are source-files specifically for this expansion chip (here), however I have no idea what the "DuetNG" denomination is about to be honest. Also, this branch seems to be of the 2.x firmware only?
        dc42 administrators @t0bias
        @t0bias, which firmware version are you using? In particular, part of that code was rewritten between versions 3.2.2 and 3.3beta1, so what works in one might not work in the other.
        I can increase the number of available GpOut ports in the next 3.3beta. Would 20 be sufficient?
        • t0biasundefined
          t0bias
          @dc42 thanks for your reply. I am using version 3.1.1, would a upgrade fix the issue?
          yes, 20 would be sufficient, maybe a bit more would be even better still? 😉
            @t0bias said in Additional outputs using a SX1509B Expander:
            An upgrade to 3.3beta1 might possibly fix it, if it doesn't then let me know and I'll implement a fix in 3.3beta2.
            Memory is rather tight on the Duet 2, so I'll set it to 20 in 3.3beta2. It's already 32 on Duet 3 and 3 Mini.
            • t0biasundefined
              t0bias
              I upgraded to 3.3beta1 today, but it still doesn't work unfortunately
                Thanks, this is on my list to test/investigate.
                  I have just tested this, and ports sx1509b.0, .1 and .2 all work for me using RRF 3.2.2 and also using RRF 3.3beta1. I didn't test the other ports.
                  Points to note:
                  1. M115 will report the SX1509B if it is detected:
                  04/03/2021, 11:17:06 	m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3beta1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 + SX1509B expander FIRMWARE_DATE: 2021-02-14 16:00:49
                  1. My test system includes a very old DueX5. On these old boards, the TWC and TWD pins are labelled the wrong way round on the 10-pin expansion header. They are also labelled incorrectly on the wiring diagrams at https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams for the 0.6 and 0.7 boards. On all DueX revisions, TWC (aka SCL) is next to the ground pin at the end of the header.
                  • t0biasundefined
                    t0bias
                    Strange, the SX1509B is in fact detected:
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3beta1 ELECTRONICS: Duet WiFi 1.02 or later + SX1509B expander FIRMWARE_DATE: 2021-02-14 16:00:49
                    however the pins don't get driven high (or low) using the M42 commands.
                    I am confident the I²C-Wiring is correct, since I tried using a MCP23017 based relay board that responds to I²C-Commands just fine.
                    Any suggestions or ideas are highly appreciated!
                    DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • DIY-O-Sphereundefined
                      DIY-O-Sphere @t0bias
                      @t0bias
                      Have you checked the I2C address?
                      It has to be set to 0x71
                      Here some code to test it directly with M260
                      https://forum.duet3d.com/topic/13911/sx1509-on-maestro-does-it-work/3
                      (UTC+1)
                        @t0bias, if the board is detected then the I2C pins are connected correctly and the slave address is set correctly.
                        How are you testing the outputs of the SX1509B? I have connected each output through a 100 ohm resistor to one of the cathodes of a 2-digit common anode 7-segment display, with the anodes connected to +3.3V.
