    3wire fan on 1LC out2 -- unknown pin name
    266
    • oliofundefined
      oliof
      I am using the wait time on the next 3.3 beta to upgrade my hotend -- titanium heatbreak, maxiwat, noctua fan.
      The noctua fan comes with 3 wire, and I wanted to connect the yellow wire to get tacho readings from it.
      Looking at the 1LC documentation (I have a 0.6 board but it seems the same for 0.6 and 1.0), and the M950 documentation, I changed the following configuration:
      M950 F1 C"10.out2" Q5000 (which works)
      to
      M950 F1 C"10.out2+10.out2.tach" Q5000
      This results in the following errors:
      Error: M950: Unknown pin name '10.out2.tach'
      Error: M106: Fan number 1 not found
      Has the pin name changed? Is it maybe not supported on the 0.6 1LC board? Did I mess up the configuration?
      • fcwiltundefined
        fcwilt
        @oliof said in 3wire fan on 1LC out2 -- unknown pin name:
        It appears that you only need to use the board address once.
        I just tried it on my test setup and M950 F1 C"10.out2+out2.tach" Q5000 was accepted.
        • oliofundefined
          oliof
          It occurred to me to test this in the meanwhile and I can confirm this works. I guess the need to use a pin on another toolboard for this is rather rare...
          • fcwiltundefined
            fcwilt @oliof
            What do you mean?
            • oliofundefined
              oliof
              Imagine more 3 wire fans on the toolhead I would like to read the tacho wire, but no inputs are free -- and I would want to read it off another toolboard or even the main control board. Then it would be useful to be able to set the tacho pin to address.name rather than inheriting the address from the first pin definition.
              Maybe this can never work? Then ignore this idea.
              • fcwiltundefined
                fcwilt @oliof
                The idea of the 1LC is to keep most of the wiring at the extruder - correct?
                Not having used one to date it appears to be designed to support two fans - one for the cold end and one for the part I would imagine.
                I can see a situation where you might need more than two fans - a printer I am working on now has two fans for part cooling.
                Perhaps post a suggestion to support three fans.
                • oliofundefined
                  oliof @fcwilt
                  @fcwilt I did run two fans in parallel for part cooling, worked well. And while the idea of the toolboard is to keep the wiring to it, not all real world circumstances keep to the idea space (i.e., for some reason my probe stopped working on the toolboard, but works on the main board ... so I bit the bullet and pulled a longer cable because my debugging went nowhere other than "normal switches work").
                  • fcwiltundefined
                    fcwilt @oliof
                    Darn the "real world" for always getting in the way of what we want to do. 😉
                    I vaguely recall that some firmware change broke Z probes on expansion boards - but my memory is not what it used to me.
                    For me the Duet 3 line (other than the Mini) are a work in progress that I am testing on my workbench but will not be using in any printers until things seem as if they are sorted out.
                    • oliofundefined
                      oliof
                      I like to live dangerously (-: this is a project printer. It's too big for most of my prints so it's only an annoyance, but not critical if something doesn't work. And someone has to eat the dogfood so you will get you matured Duet3 experience later on (-:
                      • fcwiltundefined
                        fcwilt @oliof
                        Thank you for your sacrifice - I hope it doesn't give you indigestion.
