    Syringe Pumps / Depositing Viscous Materials
    Using Duet Controllers
    1.3k
    • DocTruckerundefined
      DocTrucker
      Morning all,
      Year or so absent but returning to active duty!
      Got a job on that is based around a large (but sub metre axis) printer that will ultimately be used with printing vicous fluids. Just had a quick look on the documentation but there doesn't appear to be anything on syringe pumps there? I know there has been people working with clay printers, have I missed the doc or is all info contained only in the forums?
        Best bet would be looking for some clay printing threads. There's no specific documentation. Basically you just need to set the extruder speed/gearing/steps correctly to push the right amount. It's really not so different.
          DocTrucker
          I'm thinking about a pair of syringes with end stop switches and isolation valves. Selection of the latter may prove tricky, but would be isolated from the duet as far as possible. I believe an end stop triggered macro would suffice to change over active syringe.
          Where I begin to come a little unstuck would be after I have isolated the empty syringe how would I carry out a retract (sucking in new gunk through a non-return) concurrently to the machine carrying on printing? One of the discussed benefits of RRF2 & 3 was supposed to be concurrent actions right?
            Phaedrux Moderator @DocTrucker
            @DocTrucker said in Syringe Pumps / Depositing Viscous Materials:
            I'm not sure that's possible yet.
              T3P3Tony administrators
              @tom_lauerman posted quite a bit about clay printing and is a real expert.
              Multiple concurrent gcode streams (what you are referring to here) is not yet implemented so you would need to pause the print to run the macro that refilled the syringe or possibly post process the gcode to run that inline (but not sure if that would work well - would depend on what needed to happen concurrently).
                DocTrucker
                Thanks guys, I will search for the user at my leisure. Not working on clay as it happens, but it's a close enouch topic to be relevant.
                tom_lauermanundefined 1 Reply Last reply Reply Quote 0
                • tom_lauermanundefined
                  tom_lauerman @DocTrucker
                  @DocTrucker Hello all, and thanks to @T3P3Tony for the shout out. I'm doing clay printing just about every day, using a dual syringe printer. However, my refilling process is quite straightforward compared to what is proposed here. I pause the print, retract the syringe, insert a fresh tube of clay, extrude a bit to prime the nozzle, and return to printing. If I do this quickly it doesn't show in the print. If I get distracted and make the switch slowly, the object being printed shrinks a little and the first fresh layer stands a bit proud of the others.
                  In these pandemic times I have been documenting what I do more vis video rather than in the classroom (I'm a teacher (of Art)). So if anyone cares to see some clay printing fairly up close with the occasional explanation of process/material/art etc. have a look here: https://www.youtube.com/channel/UCeyNCJtCUtwsq2dWv26BmRA
                  DocTruckerundefined 1 Reply Last reply Reply Quote 2
                    DocTrucker @tom_lauerman
                    @tom_lauerman Morning Tom, Great thanks. Apologies for the slow response the notification got buried in responses to another thread I dropped one post on!
                    With regards the redundant syringes I will be proposing this as a potential solution. Its a little mucky in terms of how well thought through it is but I would hope to be able to add have the syringe depleting trigger change of active extruder onto a full syringe and the re-assignement of the empty one to a spare axis so that retraction moves could be injected into to g-code in G1 moves that would not cause any stutters in the original code. It's a bit Heath Robinson, but hopefully parallel gcode streams may be possible at a later date,
                    Meanwhile I will take a look at your video. I suspect it is exactly the sort of example I was after!
                    @T3P3Tony do you know where in the list of priorities parallel gcode streams are? Six months or more like two years after a load of other dependencies?
                      DocTrucker
                      @dc42 @T3P3Tony @droftarts do you know where in the list of priorities parallel gcode streams are? Six months or more like two years after a load of other dependencies?
                        dc42 administrators @DocTrucker
                        It's hard to say. We have one other user wanting parallel GCode streams at present. The low-level support is already implemented, but we need to decide on the mechanisms that will control the second stream. Many use cases would be served by a single GCode print file containing commands for both streams, with an additional command that forces whatever stream is ahead to wait for the other to catch up. That wouldn't work for your use case, which needs to send commands to the second stream from a separate file such as a trigger macro.
                          DocTrucker @dc42
                          Currently my only option appears to be:
                          • Trigger a macro on the syringe approaching end of travel.
                          • [Macro] trigger a change of tool (or swap drives for active tool) to the spare syringe and drive.
                          • Resume print.
                          • Use the raspberry pi based live g-code parsing to inject moved into vfollowing G1 commands that would not delay the overall G1 move, but would allow the slow, incremental refill of the syringe.
                          With concurrent moves this would look something like:
                          • Macro triggered by limit switch on syringe.
                          • [Macro] Wait for moves on currently inactive (unlikely to be any moves underway) syringe to complete.
                          • [Macro] change of tool (or swap drives for active tool) to the spare syringe and drive.
                          • [Macro] Run a G1 command that runs in parallel to the other g code commands that refills the syringe.
                          • Resume print.
                          • [Syringe comfortably refills in the time taken to deplete the second syringe]
                          • [Macro] change of tool (or swap drives for active tool) to the full syringe and drive.
                          • etc...
                          More bullet points in the second list but it is far easier (for me) to implement!
                            Let's suppose that we provide the following mechanisms:
                            1. A mechanism to assign each axis to one or other movement queue. So in M584 you would specify which movement queue any new axes you create would be assigned to. That assignment would probably be fixed.
                            2. A mechanism for wait for both movement queues to empty (probably M400 with an extra parameter).
                            3. Movement commands involving axes assigned to one movement queue would be permitted to happen concurrently with movement commands involving axes assigned to the other movement queue.
                            Would that be sufficient for your use case? If you think it would, can you write the macros that would be needed?
                            DocTruckerundefined 3 Replies Last reply Reply Quote 0
                              DocTrucker @dc42
                              @dc42 I will have a look at that and respond shortly. Just cleared some other work from my desk to leave me able to tackle this.
                                DocTrucker @dc42
                                @dc42 How's this looking (need to double check pin labelling for expansion card)...
                                Config file snippets:
                                M584 X0 Y1:3 Z2 E5 A4 B6               ; Apply drive mapping to axes - E on expansion card.
        ; A4 = Physical rotational axis connected to main board.
        ; E5 = Primary Syringe Extruder connected to expansion board.
        ; B6 = Secondary Syringe Extruder connected to expansion board.
                                ; M92, M350, M566, M203, M201, M906 all as expected, B settings mirror E.
                                M574 B2 S1 P"e5stop"                   ; Set active low endstops on Z via pin e5stop for secondary syringe pump.
                                ; Define inputs
                                ; e4stop = Primary syringe extruder empty (on expansion board)
                                ; e6stop = Secondary syringe extruder empty (on expansion board)
                                M950 J0 C"^e4stop"                     ; Input 0 uses e3Stop pin, pullup enabled
                                M950 J1 C"^e6stop"                     ; Input 1 uses e4Stop pin, pullup enabled
                                ; Define triggers
                                M581 T2 P0 S0 R0                       ; Run sys/trigger2.g on falling edge on input 0 at any time.
                                M581 T3 P1 S0 R0                       ; Run sys/trigger3.g on falling edge on input 1 at any time.
                                M98 P"trigger2.g"
                                trigger2.g
                                ; This is used to:
                                ;     Map the secondary syringe extruder drive to B.
                                ;     Map the primary syringe extruder drive to E.
                                ;     Drive the B axis to it's limit.
                                ;     Carry on with pint while B retracts & refills.
                                M400 [magic argument to wait for parallel moves to complete]
                                M584 E5 B6                             ; Apply drive mapping to axes - E on expansion card.
        ; E5 = This syringe extruder.
        ; B6 = other syringe extruder.
                                ; e3stop = Primary syringe extruder full (on expansion board)
                                ; e5stop = Secondary syringe extruder full (on expansion board)
                                G1 [magic argument to make this move parallel] B-100 H1
                                ; Print process continues
                                trigger3.g
                                ; This is used to:
                                ;     Map the primary syringe extruder drive to B.
                                ;     Map the secondary syringe extruder drive to E.
                                ;     Start driving the B axis to it's limit.
                                M584 E6 B5                             ; Apply drive mapping to axes - E on expansion card.
        ; E6 = This syringe extruder.
        ; B5 = other syringe extruder.
                                M574 B2 S1 P"e3stop"                   ; Set active low endstops on Z via pin e3stop
                                Thankfully I should be able to test most of this aside from having moves running in parallel.
                                  DocTrucker
                                  Making progress! Test rig assembled for dual syringing, just need to work on the fitting the two switches per axis and get on with testing the non-parallel move parts of the macros...
                                  https://youtu.be/KzCh8J0NIkU
                                  Looking at the pause on flow (although this is driving at a higher rate than I would need) I think I may need to do a stages switch over for the syringes where I use mix ratios to go from 100% one syringe to 100% the other in a number of steps, rather than one step.
                                  @dc42 would it be neater than what I proposed a couple of posts ago to change mixing ratios on the fly and have some way of excluding an extruder drive from lock in with the others for the retract?
                                    DocTrucker
                                    ...some of that pause is due to the hysteresis introduced by the slight shifting of the syringe in the holder, and in the part that holds the plunger handle.
                                      DocTrucker
                                      More testing. Two switches are wired up to the e0 and e1 inputs. The e0 switch calls trigger2.g and e1 is wired up as the limit for axis B. (Need to test whether you can drive to home switch on E axis)
                                      This video shows the basic function. Empty switch is pressed which calls for a drive to home. The home limit is then triggered when the cylinder is full.
                                      https://youtu.be/YiImdOBnOK8
                                      The following video simulates what would happen if the axis were triggered in the middle of a move. You can clearly see the trigger is a lower priority than the G1 command. The G1 move is started, the cylinder move is started, the empty switch pressed and the G1 move completes before executing the trigger macro:
                                      https://youtu.be/QrsB7TNTLZM
                                      Can this be changed so that the trigger is a higher priority than G1?
                                      If so is there a guide to how I could store the position of the axis before the home drive and then re-apply it after the home drive to save it doing some strange things? This may also be useful if swapping from one drive to the other as the active extruder.
                                      If the trigger priority can't be changed it has obvious implications on the positioning of the switches, and forces a requirement to parse the g-code. There must be spare space after the switch trigger, and the gcode must be parse to ensure no extruder move is long enough to travel further than that distance.
                                      Edit: Confirmed drive to limit does not behave the same on the extrusion axis as the other axis. There doesn't appear to be a H parameter that means the G1 will terminate on a specific input.
                                        There's no real way to interrupt a long G1 move at the moment. Breaking the single long move up into smaller shorter moves would allow an interrupt to get in between.
                                        • gaweyoundefined
                                          gaweyo
                                          Could perhaps remap endstops instead of triggers?
                                            DocTrucker
                                            Currently working on using the trigger to signal the syringe is nearly empty and swapping the drives around with M584 between E and B so I can do a home drive in the B axis and carry on with the other axis as E, which can't do home drives.
                                            Very nearly working as it should do - but obviously no parrallel motion without gcode parsing. To be fair since the syringes are fixed volume the switches could all be precoded in the build file.
                                            Some oddness that smells like a bug but need to do some more work on that before raising it.
                                            Edit:
                                            Bug1: https://forum.duet3d.com/topic/22292/bug-rrf-3-3beta2-g92-b0-changes-e-axis-position
                                            Bug2: https://forum.duet3d.com/topic/22295/bug-2-rrf-3-3beta2-axis-hanging-after-m584-re-assignemnt/10
