    Home Y wont home...
    • wingtipundefined
      wingtip
      Hello again...
      On my custom big printer im building i now have both x motors working properly, both z motors working properly, and have just finished the y motor install. I can move it from min to max travel with M256 that allows movement of non homed axis for testing, but when i hit "Home Y" button, the z lifts up a bit, then the Y moves a short distance but never does the big move towards the endstop for the initial pass... ive tried to set things up similiar to the x axis but it just wont do the - move.
      Below is my config files and motor drive assignments for clarity. Can someone look at the home Y file and see if it looks normal?
      homey.g
      homex.g
      config.g
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
      • fcwiltundefined
        fcwilt
        In the future if you will post your files using the </> tag (copy and post into it) we won't have to download your files to look at them.
        I 've reposted them for you.
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 03 2021 15:26:56 GMT-0600 (Central Standard Time)
        G90                                            ; send absolute coordinates...
        M83                                            ; ...but relative extruder moves
        M550 P"My Printer"                             ; set printer name
        M552 S1                                        ; enable network
        M586 P0 S1                                     ; enable HTTP
        M586 P1 S0                                     ; disable FTP
        M586 P2 S0                                     ; disable Telnet
        M569 P0 S0                                     ; physical drive 0 goes reverse
        M569 P1 S0                                     ; physical drive 1 goes reverse
        M569 P2 S1                                     ; physical drive 2 goes forwards
        M569 P3 S0                                     ; physical drive 3 goes reverse
        M569 P4 S0                                     ; physical drive 4 goes reverse
        M569 P5 S0                                     ; physical drive 5 goes reverse
        M584 X0:3 Y1 Z2:5 E4                               ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
        M92 X395.52 Y80.00 Z400.00 E420.00              ; set steps per mm
        M566 X300.00 Y900.00 Z180.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
        M203 X4000.00 Y4000.00 Z400.00 E1200.00        ; set maximum speeds (mm/min)
        M201 X400.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
        M906 X1400 Y1000 Z1200 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                        ; Set idle timeout
        M208 X0 Y0 Z0 S1                               ; set axis minima
        M208 X800 Y440 Z400 S0                         ; set axis maxima
        M574 X1 S1 P"!xstop+!e0stop"                            ; configure active-high endstop for low end on X via pin xstop
        M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
        M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
        M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
        M557 X15:215 Y15:195 S20                       ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
        M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                        ; map heated bed to heater 0
        M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
        M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
        M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
        M563 P0 D0 H1 F0                               ; define tool 0
        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
        M575 P1 S1 B57600                              ; enable support for PanelDue
        T0
        ; homex.g
        ; called to home the X axis
        ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time)
        G91                      ; relative positioning
        G1 H2 Z5 F6000           ; lift Z relative to current position
        G1 H1 X-805 F400   ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit
        ; go back a few mm
        G91
        G1 H2 X5 F1800        ; go back a few mm
        G1 H1 X-10 F360   ; move slowly to X axis endstop once more (second pass) H1 checks for endstop hit
        G92 X0
        G90
        ; G1 H2 Z-5 F2000          ; lower Z again
        G90                      ; absolute positioning
        ; homey.g
        ; called to home the Y axis
        G1 H1 Y-505 F900  ; move quickly to Y axis endstop and stop there (first pass)
        G91
        G1 H2 Y5 F1800    ; go back a few mm
        G1 H1 Y-10 F360  ; move slowly to Y axis endstop once more (second pass)
        G92 Y0
        ;G1 H2 Z-5 F6000   ; lower Z again
        • fcwiltundefined
          fcwilt
          Check your M574 commands in config.g
          One does not have the ! character the others do.
          • wingtipundefined
            wingtip
            If your saying thats the problem the missing "!" , i can correct that but that code was given to me by another forum user here in another thread. I am not used to this reprap 3 stuff yet and that entire config g file was edited by another user in that thread. I will add it and test again. Thank you... will let you know shortly.
            • wingtipundefined
              wingtip
              That solved it. Thank you sir!
              Now to decide whether to configure gcode for the bl touch or build the bed first... id rather test it without the bed so i dont smash anything lol.
              • fcwiltundefined
                fcwilt @wingtip
                @wingtip said in Home Y wont home...:
                Glad I could help.
