    Firmware bundle 3.3beta2 released
    Beta Firmware
    19
    49
    4.5k
    • Stephen6309undefined
      Stephen6309 @dc42
      @dc42 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3beta2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-03-10 13:39:39
      Duet TOOL1LC firmware version 3.3beta2 (2021-03-10 10:06:22)
      Duet Web Control 3.3.0-b2
      PrusaSlicer 2.3.0 + win64
      Layer Chart, layer count and Time estimates don't update.
        droftarts administrators @Stephen6309
        @Stephen6309 said in Firmware bundle 3.3beta2 released:
        Are you using SBC or stand alone mode? see https://github.com/Duet3D/DuetWebControl/releases/tag/v3.3-b2
        Rewrote backend for layers chart in standalone mode
        I don't think the SBC version has been updated yet, as there have been some changes in the firmware related to layer height since 3.2.2.
        Layer chart and layer count work for me as job progresses, in stand alone. However, estimations based on layer time (which was always the most inaccurate estimate), and the parsing of the file to count how many layers there are before printing, have been removed, because it was requiring more and more effort and memory to keep up with the ever-changing notation in slicers.
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
          Stephen6309 @droftarts
          @droftarts Yes, with PI 4, missed that. Update: time estimates are working on the current print. Layer count is the on the line above the layer chart, that shows the file progress.
            In 3.3beta2 the layer count and current layer time are only available if the GCode file being printed includes layer number comments.
            DaveAundefined 1 Reply Last reply Reply Quote 0
              Stephen6309
              Duet 3 Mini, updated to 3.3beta3. No updating in Layer chart or file completion.
              • DaveAundefined
                DaveA @dc42
                @dc42 My current file is printing without updating the layer chart. The file, from Simplify3D, has an entry such as ; layer 14, Z = 2.800 for every layer. Is there something else needed?
                • DaveAundefined
                  DaveA @DaveA
                  Something strange is happening. As I was typing my previous post I was seeing that the Layer Chart was not updating and the printer was on layer 7. I just checked back again and the layer chart has been filled from layer 2 with 0 time up to layer 10. Not sure what happened to layer 1.
                  Also noticed that the button option to show all layers or the lastnn is gone. Is this intentional?
                    droftarts administrators @DaveA
                    @Stephen6309 @DaveA Can you check you have updated DWC to Duet Web Control 3.3.0-b2? I had this when I was running previous RRF 3.3betas with DWC 3.2.2, but should be fixed in standalone DWC (I think not DWC SBC version, though). I got nice graphs from both simulation and real print.
                    Simulation:
                    Same file, real print:
                    These on Duet 2 Maestro (delta kinematics), Duet Web Control 3.3.0-b2 and RepRapFirmware for Duet 2 Maestro 3.3beta2 (2021-03-10)
                    • DaveAundefined
                      DaveA @droftarts
                      @droftarts Settings General reports: Duet Web Control 3.3.0-b2
                      I'm going to start another print in the morning and pay closer attention.
                        @DaveA, if DWC isn't displaying layers you can send M409 K"job" during the print to check whether RRF knows the current layer number.
                        • tekkydaveundefined
                          tekkydave
                          RRF 3.3beta2 & DWC 3.3beta2 installed on Duet2 Wifi
                          Edit from the near-future: see my next post for the solution 😀
                          Note: I'm only testing this in simulation in case that makes a difference.
                          I'm not getting any layer counts or graph when slicing with PrusaSlicer 2.3. Works ok when tested with Cura (which I don't use anymore).
                          The PrusaSlicer gcode seems to be missing the
                          ;LAYER:0
                          lines that Cura puts in.
                          and seems to have this at every layer change instead
                          ;LAYER_CHANGE
                          ;Z:0.3
                          ;HEIGHT:0.3
                          These are my firmware settings in PrusaSlicer
                          Have I missed something on the PrusaSlicer config side or does it not support the necessary comments (yet).
                          ~ tekkydave ~
                          D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                          FreeCAD, PrusaSlicer
                            tekkydave
                            A simple workround for PrusaSlicer is to add a custom gcode to the Printer Settings:
                            ~ tekkydave ~
                            Stephen6309undefined 1 Reply Last reply Reply Quote 3
                              @DaveA @Stephen6309 Apologies, I realise that I was running gcode sliced with Cura, which puts in:
                              ;LAYER_COUNT:125
                              ;LAYER:0
                              at the first layer, and
                              ;LAYER:1
                              etc at each layer change. If you use @tekkydave 's work around above for PrusaSlicer (and any other slicer that omits this) the layer count and chart should work correctly.
                                deckingman
                                Just to add that the "before layer change" G-code section for Slic3R and it's variants like the Prusa edition, is under "Printer Settings". So if you have multiple printer profiles as I have (15 in my case) then you need to add that layer change g-code to all of them.
                                Oh and of course, if you want layer times and stats to show up on any parts that you've already sliced, then you'll have to re-slice them. Just sayin'....
                                  To complicate things further, some slicers (e.g. Cura, Ideamaker) count the first layer as 0, others (e.g. S3D) start from 1. Currently, if RRF sees ;LAYER n then it will assume layers start from zero and add 1 to n before storing it in the OM). If RRF sees ;layer n then it will assume that n starts from 1.
                                  I don't know whether PrusaSlicer starts from 0 or 1.
                                  deckingmanundefined tekkydaveundefined oliofundefined 3 Replies Last reply Reply Quote 0
                                    deckingman @dc42
                                    @dc42 said in Firmware bundle 3.3beta2 released:
                                    ............ I don't know whether PrusaSlicer starts from 0 or 1.
                                    I just tried it and can say that Prusa Edition starts with the first layer being 0.
                                    Edit. The "LAYER" is shown as upper case in the gcode file
                                      tekkydave @dc42
                                      @dc42 that explains why I don't see a layer 0 in DWC. Confused me a bit 😕
                                      ~ tekkydave ~
                                        dc42 administrators @tekkydave
                                        @tekkydave I will clarify it in the upgrade notes. We'll also hide the layer chart in the next version of DWC when layer data is not available.
                                        tekkydaveundefined 1 Reply Last reply Reply Quote 0
                                          tekkydave @dc42
                                          Yes. I had noticed the layer chart persisted until the first layer change of the next print.
                                          ~ tekkydave ~
                                          • Egrisundefined
                                            Egris
                                            Tested fw 3.3 beta 2 on my rotary delta. Has there been a change to Segments per second for this kinematic? X/Y G1 moves look like there is a very low segments per second value usesd for straight lines.
                                            With the older 3.3 version its working fine
