Lost! Toolboard not report temp and fan does not work
Brand new Duet3 Mini, 1LC toolboard.
On my bench at the moment. 12V PSU feeding 1LC and Duet3 Mini.
Toolboard
is address 20
has a 2 wire fan connected to out1 to pins +12v and out1 - cannot control it
E3d sensor in Temp0 - cannot read itCan see the board running m155 b20
m115 b20 Duet TOOL1LC firmware version 3.2.2 (2021-02-11)
on a boot I get
Warning: Incompatible firmware, please upgrade as soon as possible
I have updated it from the file in the system directory following the instructions.
Also get these messages
14/03/2021, 13:55:33 Warning: M950: Sensor number 1 has not been defined 14/03/2021, 13:55:33 Error: M308: Board 20 received unknown msg type 6011 14/03/2021, 13:55:32 Connection established
Checked and checked again and again.
Config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"RailCore II" ; set printer name M669 K1 ; select CoreXY mode G4 S1 ; wait for expansion boards to start ; Drives M569 P0.0 S1 ; X Axis - physical drive 0.0 goes forwards M569 P0.1 S0 ; Y Axis - physical drive 0.1 goes backwards M569 P0.2 S1 ; Left Front physical drive 0.2 goes forwards M569 P0.3 S1 ; Left Rear physical drive 0.3 goes forwards M569 P0.4 S1 ; Right physical drive 0.4 goes forwards M569 P20.0 S1 ; physical drive 20.0 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4 E20.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X230 Y210 Z200 S0 ; set axis maxima ; Endstops M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^20.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-7 Y35 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"20.temp0" Y"thermistor" A"e3d" B4725 C7.060000e-8 ; M308 S1 P"20.temp0" Y"thermistor" A"Mosquito" T500000 B3950 ; configure sensor 1 as thermistor on pin 20.temp0 M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"20.out1" Q500 ; create fan 0 on pin 20.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"20.out2" Q500 ; create fan 1 on pin 20.out2 and set its frequency M106 P1 S1 H-1 ;H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue
M122
4/03/2021, 14:04:19 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta3.2+1 running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 97472 Dynamic ram: 120084 of which 28 recycled Never used RAM 43536, free system stack 198 words Tasks: Linux(blocked,73) HEAT(blocked,332) CanReceiv(blocked,904) CanSender(blocked,371) CanClock(blocked,370) TMC(blocked,56) MAIN(running,511) IDLE(ready,20) AIN(blocked,258) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:08:48 ago, cause: software Last software reset at 2021-03-14 13:55, reason: User, none spinning, available RAM 43500, slot 1 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff Task Linu Error status: 0x00 Supply voltage: min 0.0, current 23.5, max 23.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 9959, writes 11, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 9959, writes 11, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 9958, writes 11, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 9958, writes 11, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 9959, writes 11, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-03-14 14:04:20 Slowest loop: 1.52ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 11.2MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages sent 0, send timeouts 0, longest wait 2ms for type 6026, free CAN buffers 15 === SBC interface === State: 4, failed transfers: 1 Last transfer: 7ms ago RX/TX seq numbers: 18795/18795 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x0b264 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.59 Maximum length of RX/TX data transfers: 2836/764
Think I have everything included.
Assistance would be appreciatedRegards
Paul -
I don't use SBC mode so this may not apply.
According to the info you posted your Mini is running older firmware than the 1LC.
I don't think that will work.
** Update **
Added another fan to out2 on the 1lc and rebooted everything including the SBC, (yes I was powering off the Duet Boards before playing)
Fans are now working but still getting the firmware and M308 errors.P.
@fcwilt Read the manual again on how to update Duet firmware with a SBC.
It is afaik up to-datepi@RailCoreII:~ $ sudo apt update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Hit:3 https://pkg.duet3d.com stable InRelease Fetched 15.0 kB in 1s (11.2 kB/s) Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. pi@RailCoreII:~ $ sudo apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
P.
@PaulHew said in Lost! Toolboard not report temp and fan does not work:
Well you posted that the 1LC was running 3.2.2 and the Mini was running 3.2-beta3.2+1.
Is that what you expect to see?
From the manual
Updating firmware with attached Single Board Computer Use 'sudo apt update' and 'sudo apt upgrade'.
Oh well, fixed now. uf2 file was required, uploaded via dwc.
From the manual
Glad you got it sorted.
