    Anycubic Predator Delta effector tilt
    711
      45C isn't anything to be worried about. 85c maybe.
      But you can calibrate the sensor to see how accurate it actually is.
      https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
      What firmware versions specifically are you using? Which filament sensor is it specifically? Which port do you have it connected to?
      • gpermanundefined
        gperman
        RR3.1.1
        3 wire low signal when filament present microswitch
        E0 stop connector
          M591 D0 P2 C"e0stop" S1 should do it.
          What are you expecting it to do? It's only monitored during a print. Have you tried starting a print and removing the filament?
          Can you send M98 P"config.g" and post the results along with your current config.g?
          • gpermanundefined
            gperman
            @Phaedrux said in Anycubic Predator Delta effector tilt:
            rrent confi
            ok that worked. I tried M591 D0 P2 C"e0stop" S1 first, but I put it in the endstop category. that didnt work.
            I put it at the end in custom settings and that paused the print and gave a message filament out which is what i wanted.
            here's my config for posterity or if you see anything that stands out as being incorrect.
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 489C
            G90                                                ; send absolute coordinates...
            M83                                                ; ...but relative extruder moves
            M550 P"Anycubic Predator"                          ; set printer name
            M665 L441.014:441.014:441.014 R229.410 H410.221 B185.0 X-0.097 Y0.071 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X-0.175 Y0.253 Z-0.078 A-0.22 B0.22           ; put your endstop adjustments here, or let auto calibration find them
            M552 S2 P"anycubicp"                               ; enable accesspoint anycubicp
            M586 P0 S1                                         ; enable HTTP
            M586 P1 S0                                         ; disable FTP
            M586 P2 S0                                         ; disable Telnet
            M575 P1 S1 B57600				   ; sets serial comms parameters
            M569 P0 S1                                         ; physical drive 0 goes forwards
            M569 P1 S1                                         ; physical drive 1 goes forwards
            M569 P2 S1                                         ; physical drive 2 goes forwards
            M569 P3 S1                                         ; physical drive 3 goes forwards
            M584 X0 Y1 Z2 E3                                   ; set drive mapping
            M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z80.00 E406.90                   ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00        ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E1000.00           ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                            ; Set idle timeout
            M208 Z0 S1                                         ; set minimum Z
            M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
            M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
            M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
            M558 P8 C "zprobe.in+zprobe.mod" R0.4 F2500 T15000 H5 ; set Z probe type to switch and the dive height + speeds
            G31 P100 X0 Y0 Z-0.2                            ; set Z probe trigger value, offset and trigger height
            M557 R170 S70                                      ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
            M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
            M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                            ; map heated bed to heater 0
            M308 S1 P"e0temp" Y"thermistor" T100000 B3950      ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
            M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
            M563 P0 D0 H1 F0                                   ; define tool 0
            G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
            G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
            M591 D0 P2 C"e0stop" S1                            ; activate filament runout sensor
            M501						   ; Allows stored parameters to be read
            not sure whats up with the heaters appearing overpowered. I havent had them overshoot yet.
            I also have a blobbing and light stringing at layer changes and retraction points issue that Ive been trying to get rid of with retraction, temps or pressure advance. Doing tests for a bit but so far not much luck.
              Phaedrux Moderator @gperman
              @gperman said in Anycubic Predator Delta effector tilt:
              https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
              It's just telling you how hot it thinks the heaters could get in a runaway situation.
              Would need more details on your extruder to be of much help.
              gpermanundefined 1 Reply Last reply Reply Quote 0
              • gpermanundefined
                gperman @Phaedrux
                All genuine. Mosquito w/0.4 tool steel nozzle. Bondtech BMG (flying extruder). Capricorn 1.75mm bowden tube (190mm from extruder to mosquito top entry)
                Standard chinese stepper that came with the Anycubic Predator.
                currently on hatchbox pro PLA that sits in a desiccant filled bucket. Putting a food dehydrator together to dry rolls if needed.
                  What retraction and pressure advance settings?
                  • gpermanundefined
                    gperman
                    M572 D0 S0.09 right now.
                    retraction:
                    6mm length
                    80mm/s
                      Photos of example prints?
                      Tool steel nozzles can be extra tricky.
                      • gpermanundefined
                        gperman
                        that and they're relatively lumpy which is my next trick I have to tackle.
                        hatchbox PLA seems to like the higher temps so i'm going to stick to the 220 area. was printing at 190...
                          Looks like some lifting on the corners. Needs more cooling?
                          And yeah higher temps with a steel nozzle to keep the plastic temp at the tip up.
                          • gpermanundefined
                            gperman
                            I’ll give that a try. I need to print a slightly better fan shroud as well.
