BLTouch doesn't always deploy Duet 3 6HC
Firmware installation
11
47
2.9k
    Nuramori @Veti
    @Veti there was an issue in a previous firmware version that P500 was a problem, and reducing it to P100 would help, per David’s suggestion. It did. After that version I went back to P500 as a mid value and the problem re-emerged. Going to P100 fixed it, so I’ve kept the value.
    undefined 1 Reply Last reply 7 Feb 2021, 16:40 Reply Quote 0
      ctilley79 @Nuramori
      @Nuramori Is your issue that the probe deploys and doesn't trigger, or are you having an issue with the probe not deploying at all?
      undefined 1 Reply Last reply 7 Feb 2021, 20:46 Reply Quote 0
        Nuramori @ctilley79
        @ctilley79 It was that it would deploy but not trigger.
        undefined 1 Reply Last reply 7 Feb 2021, 21:54 Reply Quote 0
          ctilley79 @Nuramori
          @Nuramori ok. That’s different than my issue. If I can get mine to deploy, it works flawlessly. Mine is not reacting to m401 or m402 commands after a given period of time.
          undefined 1 Reply Last reply 8 Feb 2021, 04:54 Reply Quote 0
            User3D @ctilley79
            @ctilley79 I wanna know if you have deployprobe.g and retractprobe.g in /sys only !!!!! (If you do , can you post them here)
            undefined 1 Reply Last reply 9 Feb 2021, 16:15 Reply Quote 0
              ctilley79 @User3D
              @User3D Yes. They are automatically generated if you select P9 as the probe type if i'm not mistaken. Here's a copy of mine
              M280 P0 S10 ; deploy BLTouch
              M280 P0 S90 ; retract BLTouch
              undefined 1 Reply Last reply 10 Feb 2021, 05:31 Reply Quote 0
                User3D @ctilley79
                @ctilley79 said in BLTouch doesn't always deploy Duet 3 6HC:
                Yes they are, I just wanted to see if you've changed something that is causing all .
                  ctilley79
                  Any update on this? just broke a bltouch probe because of this issue.
                  undefined 1 Reply Last reply 16 Mar 2021, 03:50 Reply Quote 0
                    SJI
                    I was having issues on IO_6, no deploy. checked wiring etc, all ok from that end. Changed to IO_7, now it works.
                      Phaedrux Moderator @ctilley79
                      I've poked DC42 to take a look again when he has a moment.
                      Were you able to try a different BLTouch?
                        bzad
                        Hi was this issue solved? I’m having this issue ive brand new bltouch connected to io7
                        undefined 1 Reply Last reply 19 Aug 2021, 03:42 Reply Quote 0
                          Phaedrux Moderator @bzad
                          @bzad said in BLTouch doesn't always deploy Duet 3 6HC:
                          Probably best to start a new thread with your issue.
