    Warning on the console since update
    Beta Firmware
    800
    • fcwiltundefined
      fcwilt @appjaws
      @appjaws said in Warning on the console since update:
      No they are not from my macro, I think they are coming from the internal G31 code.
      As I stated, the macro is not using M120 or M121.
      I have also checked the macro and all indents are tabs.
      When I get those warnings the line number refers to the line in one of my gcode files where I am using conditional code requiring indentation.
        Post your files as uploads so we can look at them in a text viewer that shows the difference between tab and space characters.
        • appjawsundefined
          appjaws
          Here is the relevant file, thanks for your interest
          Auto Set Trigger Height.g
          appjaws - Core XYUV Duet Ethernet Duex5
          firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
          Ormerod 1-converted to laser engraver, Duet wifi
          OpenSCAD version 2024.03.18
          Simplify3D 5.1.2
            I don't see anything in there. Could it be in the SET_LED macros that get called?
            • appjawsundefined
              appjaws
              No, The called macros are all ok, just tabs.
              Has something changed in the beta firmware in the way G31 operates?
              Simplify3D 5.1.2
              • SIamundefined
                SIam
                I had a similar problem with that error message finally was the error not in the macro file where the error point me to but at the bed.g file.
                Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                Duet WiFi 1.02 or later + DueX5
                RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                Duet WiFi Server: 1.26
                Duet Web Control 3.4.0beta4 (2021-09-27)
                • fcwiltundefined
                  fcwilt
                  I updated my 6HC to 3.3 beta 2 and I am not getting any warnings like that from invoking G31.
                    Warning: both space and tab characters used to indent blocks by line 184
                    Do you have a macro with a line 184?
                    appjawsundefined 1 Reply Last reply Reply Quote 0
                    • appjawsundefined
                      appjaws @Phaedrux
                      @Phaedrux
                      No, all my macros are quite small.
                      This is really strange, I'll check all my macros again tomorrow .
                      Simplify3D 5.1.2
                      • fcwiltundefined
                        fcwilt @appjaws
                        @Phaedrux
                        It can be any gcode file in your SYS or MACRO directory.
                        • appjawsundefined
                          appjaws @fcwilt
                          @fcwilt
                          Even if not called?
                          I'd better check all my files.
                          Simplify3D 5.1.2
                          • fcwiltundefined
                            fcwilt @appjaws
                            @fcwilt
                            Even if not called?
                            Well yes they have to called.
                            • appjawsundefined
                              appjaws
                              Problem solved, I checked all files and there were a few that had space and tabs. They now have all tabs and the error has been fixed.
                              Thank you for all who helped👍
                              Simplify3D 5.1.2
