    Warning on the console since update
    Beta Firmware
    857
      Post your files as uploads so we can look at them in a text viewer that shows the difference between tab and space characters.
      • appjawsundefined
        appjaws
        Here is the relevant file, thanks for your interest
        Auto Set Trigger Height.g
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
          I don't see anything in there. Could it be in the SET_LED macros that get called?
          • appjawsundefined
            appjaws
            No, The called macros are all ok, just tabs.
            Has something changed in the beta firmware in the way G31 operates?
            Simplify3D 5.1.2
            • SIamundefined
              SIam
              I had a similar problem with that error message finally was the error not in the macro file where the error point me to but at the bed.g file.
              Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
              Duet WiFi 1.02 or later + DueX5
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
              Duet WiFi Server: 1.26
              Duet Web Control 3.4.0beta4 (2021-09-27)
              • fcwiltundefined
                fcwilt
                I updated my 6HC to 3.3 beta 2 and I am not getting any warnings like that from invoking G31.
                  Warning: both space and tab characters used to indent blocks by line 184
                  Do you have a macro with a line 184?
                  appjawsundefined 1 Reply Last reply Reply Quote 0
                  • appjawsundefined
                    appjaws @Phaedrux
                    @Phaedrux
                    No, all my macros are quite small.
                    This is really strange, I'll check all my macros again tomorrow .
                    Simplify3D 5.1.2
                    • fcwiltundefined
                      fcwilt @appjaws
                      @appjaws said in Warning on the console since update:
                      @Phaedrux
                      It can be any gcode file in your SYS or MACRO directory.
                      • appjawsundefined
                        appjaws @fcwilt
                        @fcwilt
                        Even if not called?
                        I'd better check all my files.
                        Simplify3D 5.1.2
                        • fcwiltundefined
                          fcwilt @appjaws
                          @fcwilt
                          Even if not called?
                          Well yes they have to called.
                          • appjawsundefined
                            appjaws
                            Problem solved, I checked all files and there were a few that had space and tabs. They now have all tabs and the error has been fixed.
                            Thank you for all who helped👍
                            Simplify3D 5.1.2
