Upload file to SD card
If I use rr_upload to push a file from S3D to the Duet is there any way to force the DWC to automatically refresh the jobs list. The file gets to the Duet fine but I need to do a manual refresh to update the list.
What version DWC?
@Phaedrux Sorry about that. 3.3.0-b2
Thanks. I'm not sure if there is a way to do that, but maybe someone else like @chrishamm will have an idea when he returns.
not sure about refresh, but you should be able to select the uploaded file. check out the simplify3d script in a topic here somewhere
@gaweyo The file actually gets to the Duet just fine. But if you look at the Jobs listing in the DWC you don't see the file until you hit Refresh. Then it refreshes the entire directory taking some time updating all the file stats. If you use the upload button the file is uploaded and the list is updated immediately.
@gaweyo That works except I'm not always wanting to immediately print the file I'm uploading. The M23 selects the file and generates an error if the printer is already printing.
Anyway, never mind.
