Bed levelling - just z probe, or 2 indep. motors with G32?
729
    Reefwarrior @fcwilt
    @fcwilt The P is for the thread pitch ....
    I got this: Error: Number of calibration factors (4) not equal to number of leadscrews (3)
    undefined 1 Reply Last reply 21 Mar 2021, 20:27 Reply Quote 0
      fcwilt @Reefwarrior
      @Reefwarrior said in Bed levelling - just z probe, or 2 indep. motors with G32?:
      Arggggg.....
      My bad - I confused the S and P parameters.
      When am I going to learn to not trust to memory....
      undefined 1 Reply Last reply 21 Mar 2021, 20:31 Reply Quote 0
        Reefwarrior @fcwilt
        @fcwilt hahahaha no stress 🙂
          Reefwarrior
          Can't seem to sort out the 'Number of calibration factors....' error.....
            Reefwarrior
            Eureka!
            G32
            Manual corrections required: 0.00 turn up (0.00mm) 0.00 turn down (0.00mm) 0.76 turn up (-0.38mm) 0.81 turn up (-0.41mm)
            The M671 I used to define the springs positions was not correct.
            undefined 1 Reply Last reply 21 Mar 2021, 21:27 Reply Quote 1
              fcwilt @Reefwarrior
              Eureka!
              G32
              The : character after the X and Y?
                Phaedrux Moderator @Reefwarrior
                This setup is basically on an Ender3 with a DuetWifi.
                I wouldn't bother changing the Ender3 to a dual Z axis setup. It's not necessary. When assembled properly the design is adequate for keeping the X gantry level. The bed can be manually leveled pretty easily, and mesh compensation can take care of the rest.
                There's something to be said for simplicity. Once you add a second Z axis motor you have to calibrate it because it won't stay in sync over time.
                Also, 2 Z motors will only give you tilt correction along a single axis. You need 3 motors to do a 3 point plane. So you'd still be using mesh compensation and manual leveling anyway.
                So I say avoid a second z axis motor if the printer design allows for it.
                undefined 2 Replies Last reply 22 Mar 2021, 05:45 Reply Quote 0
                  Reefwarrior @Phaedrux
                  @Phaedrux Hi, thank you for the reply. I have extended my Z and my X axis and noticed drooping on the one side if the Z raises... hence the reason now for the second motor 🙂
                    @Phaedrux I'm probably going too complicated now, but won't it help to have 2 indep. motors, have it correct tilt and then bed level assistant for the rest? If I read it correctly, I can not have both 2 indep and MBLA at the same time, or have I misunderstood something? 🙂
                    undefined 1 Reply Last reply 22 Mar 2021, 18:46 Reply Quote 0
                      Yes you can use both, but there needs to be a reference somewhere. If you do the tilt correction based on the bed surface, but then change the bed surface itself with MBLA your tilt correction is now changed as well.
                      Maybe a better solution would be to correct for gantry tilt with 2 endstops at the top of the frame so that you're leveled to the frame as a reference. Then you can adjust the plane of the bed to match the frame.
                      undefined 1 Reply Last reply 23 Mar 2021, 03:37 Reply Quote 0
                        @Phaedrux Awesome, thanx! 🙂
                        18 out of 19
