    Intermittent extruder loss and stutters. 6HC/toolboard/RRF3.2
    59
    3.0k
    • hamelundefined
      hamel @Phaedrux
      @Phaedrux Yes, this is a first for me, and I use Duet for most things here, not just FFF printers. This was just a "let's build a printer with the spares that we have", and we chose Voron. Seems like this should be quite simple to get running, but this issue has been plaguing me for almost a month since the machine was built and wired. I don't know what else to try.
      Start:
      T0
      G28
      Pause:
      M83 ; relative extruder moves
      G1 E-2 F3600 ; retract 2mm of filament
      G91 ; relative positioning
      G1 Z20 F360 ; lift Z by 20mm
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      Resume:
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0 ; go back to the last print move
      G1 E2 F3600 ; extrude 2mm of filament
        Can you post your gcode file you are trying to print? Is there perhaps a difference in extrusion rate between the manual extrude and the print extrude commands? Maybe the print is trying to push too much filament and it simply can't?
        hamelundefined 1 Reply Last reply Reply Quote 0
        • hamelundefined
          hamel @Phaedrux
          @Phaedrux Gcode is in the first post. I have changed a few settings in the slicer, but nothing big. I've turned off retracts etc. to reduce the variables, but it really just seems that I get very low torque when printing. Maybe it has something to do with microstepping? I have tried setting the extruder to all of the microsteps, but there was no real change on either. Doesn't look like the gcode is changing the extrusion rates to anything large, they are all very small values. I can manually extrude with all of the presets except for the 60mm/s one, as that will overrun my melt rate pretty quick.
            Let's replace the board. Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
            • hamelundefined
              hamel @Phaedrux
              @Phaedrux Thank you. Just to clarify, as I Filastruder is asking, which board are you recommending replacing, just the LC1, correct?
                dc42 administrators @hamel
                @hamel said in Intermittent extruder loss and stutters. 6HC/toolboard/RRF3.2:
                Yes, just the 1LC.
                • hamelundefined
                  hamel @dc42
                  @dc42 Thank you.
                  • hamelundefined
                    hamel
                    @dc42 I just installed a new toolboard with updated firmware. I have the exact same symptoms, which are:
                    Extrudes fine with DWC
                    Extruder drive just jitters and does not turn when printing gcode
                    If I pause, I am able to extrude just fine, but again fails to extrude when resumed
                    I am using the same firmware, config.g, and gcode as posted before
                    I have put a DMM on all connections, and they pass the wiggle test
                    I have tried in SBC and standalone. I am back to SBC now.
                    Has tons of torque when commanding from DWC, but no torque when printing (I have tried a free motor with no load, and it will not even turn when printing). I do not see any gcode issue, and I think my config.g is set up correctly (could you please double check it?). My drive settings are similar to what others are using on the same extruder.
                    • hamelundefined
                      hamel
                      Any idea as to what my next step in troubleshooting this would be? I have played with config.g drive settings some more, but nothing seems to change the behavior.
                        sorry about that delay.
                        Can you confirm that the newly received tool board has been updated with matching firmware for the main board?
                        • hamelundefined
                          hamel
                          No worries. I know it only takes a day to have tons of new posts to look through.
                          Yes, I can confirm that they are both running 3.3 beta2.
                          m115 b121
                          Duet TOOL1LC firmware version 3.3beta2 (2021-03-10 10:06:22)
                          m115
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3beta2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-03-10 13:39:39
                            Thanks. Hopefully DC42 will have some time to take a look soon.
                              Hi @hamel, I'm sorry to hear that you are still having problems.
                              1. Is your config.g file still the same as when you posted it in this thread on 8 March?
                              2. Please post your config.override.g file.
                              3. Please provide a sample GCode file that hows this problem. I will try running it on my bench system using your config files.
                              • hamelundefined
                                hamel
                                @dc42 Here are my files and some gcode I am running:
                                ; Configuration file for Duet 3 (firmware version 3.3Beta2)
                                M550 P"Duet 3" ; set printer name
                                M669 K1 ; select CoreXY mode
                                G4 S2 ;wait for expansion boards to start
                                M569 P121.0 S1 ; physical drive 121.0 goes forwards
                                M569 P0.3 S0 ; physical drive 0.2 goes backwards
                                M569 P0.4 S0 ; physical drive 0.2 goes backwards
                                M569 P0.5 S1 ; physical drive 0.2 goes forwards
                                M584 X0.1 Y0.0 Z0.2:0.3:0.5:0.4 E121.0 ; set drive mapping
                                M92 X98.00 Y98.00 Z400.00 E426.00 ; set steps per mm
                                M566 X2500.00 Y2500.00 Z200.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X10000.00 Y10000.00 Z8000.00 E10000.00 ; set maximum speeds (mm/min)
                                M201 X3000.00 Y3000.00 Z200.00 E500.00 ; set accelerations (mm/s^2)
                                M906 X1100 Y1100 Z1000 E850 I30; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 X-200 Y-200 Z-1 S1 ; set axis minima
                                M208 X200 Y200 Z400 S0 ; set axis maxima
                                ; Leadscrew Locations
                                M671 X-322.5:-322.5:262.5:262.5 Y-250:300:300:-250 S20 F1.2 ; Z leadscrew positions
                                M574 X2 S1 P"io0.in" ; X min active low endstop switch
                                M574 Y2 S1 P"io1.in" ; Y min active low endstop switch
                                M574 Z1 S2
                                M558 P8 C"^!121.io0.in" H10 F600 T16000 ; set Z probe type to unfiltered switch and the dive height + speeds
                                ;M558 H15 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                G31 P500 X0 Y0 Z1 ; set Z probe trigger value, offset and trigger height
                                M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                                M557 X-200:200 Y-200:200 S100 ; define mesh grid
                                M308 S0 P"temp3" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp3
                                M307 H0 B0 S0.50 ; disable bang-bang mode for the bed heater and set PWM limit
                                M143 H0 S150 ; set temperature limit for heater 0 to 150C
                                M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
                                M950 H1 C"nil" ; free up H1
                                M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
                                M307 H1 B0 S0.5 ; disable bang-bang mode for heater and set PWM limit
                                M143 H1 S350 ; set temperature limit for heater 1 to 350C
                                M950 F0 C"nil" ; free up F0
                                M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out1 and set its frequency
                                M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out2 and set its frequency
                                T0 ; select first tool
                                config-override.g
                                ; Heater model parameters
                                M307 H0 R0.995 C146.5 D3.59 S1.00 V30.3
                                M307 H1 R7.632 C173.800:173.800 D11.40 S0.4 V28.4 B0
                                ; Workplace coordinates
                                G10 L2 P1 X0.00 Y0.00 Z0.00
                                G10 L2 P2 X0.00 Y0.00 Z0.00
                                G10 L2 P3 X0.00 Y0.00 Z0.00
                                G10 L2 P4 X0.00 Y0.00 Z0.00
                                G10 L2 P5 X0.00 Y0.00 Z0.00
                                G10 L2 P6 X0.00 Y0.00 Z0.00
                                G10 L2 P7 X0.00 Y0.00 Z0.00
                                G10 L2 P8 X0.00 Y0.00 Z0.00
                                G10 L2 P9 X0.00 Y0.00 Z0.00
                                Gcode file:
                                https://drive.google.com/file/d/1arUmgvHX2YdvrwHeZu3cwaWV2b-UkRiP/view?usp=sharing
                                Gcode snip:
                                ;FLAVOR:RepRap
                                ;TIME:3785
                                ;Filament used: 4.39049m
                                ;Layer height: 0.2
                                ;MINX:-19.925
                                ;MINY:-19.926
                                ;MINZ:0.2
                                ;MAXX:19.925
                                ;MAXY:19.926
                                ;MAXZ:30.5
                                ;Generated with Cura_SteamEngine 4.8.0
                                T0
                                M190 S80
                                M104 S260
                                M109 S260
                                M82 ;absolute extrusion mode
                                print_start
                                T0
                                G28
                                M83 ;relative extrusion mode
                                G1 F3600 E-6.5
                                ;LAYER_COUNT:150
                                ;LAYER:0
                                M107
                                G1 F600 Z0.7
                                G0 F7200 X-19.925 Y-8.452 Z0.7
                                ;TYPE:SKIRT
                                G1 F600 Z0.2
                                G1 F1440 E6.5
                                G1 F1500 X-19.915 Y-9.157 E0.02638
                                G1 X-19.867 Y-9.789 E0.02372
                                G1 X-19.739 Y-10.41 E0.02372
                                G1 X-19.533 Y-11.009 E0.0237
                                G1 X-19.254 Y-11.578 E0.02371
                                G1 X-18.906 Y-12.108 E0.02372
                                G1 X-18.58 Y-12.499 E0.01905
                                G1 X-18.444 Y-12.646 E0.00749
                                G1 X-18.165 Y-12.933 E0.01498
                                G1 X-13.073 Y-18.025 E0.26945
                                G1 X-12.588 Y-18.496 E0.0253
                                G1 X-12.106 Y-18.908 E0.02373
                                G1 X-11.577 Y-19.256 E0.02369
                                G1 X-11.007 Y-19.535 E0.02375
                                G1 X-10.408 Y-19.739 E0.02368
                                G1 X-9.787 Y-19.867 E0.02372
                                G1 X-9.257 Y-19.913 E0.01991
                                G1 X-9 Y-19.921 E0.00962
                                G1 X-8.53 Y-19.926 E0.01759
                                G1 X8.458 Y-19.924 E0.63565
                                G1 X9.158 Y-19.914 E0.0262
                                G1 X9.79 Y-19.865 E0.02372
                                G1 X10.41 Y-19.737 E0.02369
                                G1 X11.01 Y-19.532 E0.02372
                                G1 X11.579 Y-19.253 E0.02371
                                G1 X12.108 Y-18.905 E0.02369
                                G1 X12.512 Y-18.566 E0.01973
                                G1 X12.729 Y-18.362 E0.01114
                                G1 X12.942 Y-18.154 E0.01114
                                G1 X18.027 Y-13.068 E0.26911
                                G1 X18.498 Y-12.582 E0.02532
                                G1 X18.91 Y-12.1 E0.02373
                                G1 X19.257 Y-11.57 E0.0237
                                G1 X19.535 Y-11.001 E0.0237
                                G1 X19.74 Y-10.401 E0.02372
                                G1 X19.867 Y-9.78 E0.02372
                                G1 X19.912 Y-9.254 E0.01975
                                G1 X19.92 Y-8.997 E0.00962
                                G1 X19.925 Y-8.588 E0.0153
                                G1 X19.924 Y8.455 E0.63771
                                G1 X19.914 Y9.157 E0.02627
                                G1 X19.866 Y9.788 E0.02368
                                G1 X19.737 Y10.409 E0.02373
                                G1 X19.532 Y11.009 E0.02372
                                G1 X19.253 Y11.578 E0.02371
                                G1 X18.905 Y12.107 E0.02369
                                G1 X18.581 Y12.495 E0.01891
                                G1 X18.357 Y12.734 E0.01226
                                G1 X18.074 Y13.022 E0.01511
                                G1 X13.091 Y18.007 E0.26374
                                G1 X12.582 Y18.5 E0.02651
                                G1 X12.1 Y18.912 E0.02373
                                G1 X11.57 Y19.259 E0.0237
                                G1 X11 Y19.537 E0.02373
                                G1 X10.4 Y19.741 E0.02371
                                G1 X9.779 Y19.868 E0.02372
                                G1 X9.273 Y19.913 E0.01901
                                G1 X8.978 Y19.922 E0.01104
                                G1 X8.544 Y19.926 E0.01624
                                G1 X-8.462 Y19.924 E0.63632
                                G1 X-9.127 Y19.914 E0.02489
                                G1 X-9.758 Y19.865 E0.02368
                                G1 X-10.379 Y19.736 E0.02373
                                G1 X-10.978 Y19.531 E0.02369
                                G1 X-11.547 Y19.251 E0.02373
                                G1 X-12.042 Y18.928 E0.02212
                                G1 X-12.231 Y18.787 E0.00882
                                G1 X-12.745 Y18.347 E0.02532
                                G1 X-12.987 Y18.11 E0.01267
                                G1 X-18.031 Y13.065 E0.26694
                                G1 X-18.502 Y12.578 E0.02535
                                G1 X-18.913 Y12.096 E0.0237
                                G1 X-19.26 Y11.566 E0.0237
                                G1 X-19.537 Y10.996 E0.02371
                                G1 X-19.741 Y10.396 E0.02371
                                G1 X-19.867 Y9.775 E0.02371
                                G1 X-19.912 Y9.255 E0.01953
                                • hamelundefined
                                  hamel
                                  I have just confirmed that this is not extruding, but I did have one instance of it extruding with gcode until I paused for less than 5 seconds, and then it reverted back to the same behaviour of not extruding upon resuming the print. I have tried 20 times since, and all attempts do not extrude. I can still extrude just fine with DWC at very high rates, I have tested extrusion with all wires being tugged and wiggled, and I have tried 3 different motors and motor cables, all showing no change.
                                    Thanks, I'll try that file on my Tool Changer, which uses tool boards.
                                    • hamelundefined
                                      hamel
                                      Thank you @dc42 . Just as a note, I do not have to reboot to get a good print going (when it does happen). I just cancel and restart over and over, and after a few tries it will start working correctly. When it does not extrude, I can still pause and extrude fine, but it will only extrude with gcode when I do multiple "restart print"s.
                                        @hamel, thanks. The firmware I will be using for this test is at https://www.dropbox.com/sh/6203euyyobllic5/AABTHIbn7F_maK9p-oy7vq3Ea?dl=0. It's later than 3.3beta2 but I am not aware of any changes that are likely to affect this behaviour.
                                        I note that your M122 B121 reports say that the VIN voltage to the tool board is about 30V. Is that correct?
                                          I am running your print for the first time, and it is printing OK. However, I am running in standalone mode because the machine doesn't have an attached SBC.
                                          It occurred to me that one possible explanation is that fort reasons unknown, the GCode input channel for the print form file has somehow switched to absolute extrusion. This would account for why you are still able to extrude form DWC, and also for why restarting the print sometimes clears the problem (because your GCode file includes the M83 command).
                                          Therefore, please can you provoke the problem, then pause the print, then use the Object Model explorer plugin in DWC to examine the 'inputs' key. Element number 2 in this list should look something like this:
                                          ![0_1616776184818_96152409-4bcb-4e0d-bcce-9e1b052e29da-image.png](Uploading 100%)
                                          [Sorry, upload failed, I need to switch browser - I will post the image shortly.]
                                          [Sorry again, I can't login at all from FireFox at present.]
                                          What I expect is that inputs[2] shows name="File" and drivesRelative="true".
                                          • hamelundefined
                                            hamel @dc42
                                            @dc42 Thank you. I think you might be on to something.
                                            When it is extruding fine, and when it is not extruding, the input2 name is file, but the drivesRelative is always false (when extruding correctly or when not extruding). Sending m83 or m82 does not change the print or the issue. If I send a m82, I should see that object model change to a drivesRelative=true, and with an m83 I should see it change to a drivesRelative=false. Is that correct? That is not the behaviour I am seeing. I see no change in the object model values.
